Electrical Woes
Old Feb 19, 2013 | 06:33 PM
Stealth94rttt's Avatar
Stealth94rttt
Electrical Woes
I have been having an intermittent (2 times in the past 2000 miles) oil pressure gauge not reading. As I own a 6.0L I understand that this is just a pressure switch in reality and if the engine was starved of oil the HPOP system would kill the engine. The first time the oil gauge went out it was raining out. The second time was after going through a carwash and getting the underbody wash. At this time my battery light also came on for a few seconds. Both problems seemed to go away after an engine restart. Today it is snowing lightly and my battery light came on again. I happened to be monitoring the battery voltage and FICM voltage via OBD II using Torque app. At no time while the battery light was on today did the battery voltage drop below 13.5V. The FICM was also stable at 48.5+/-.5V. As the battery voltage read by the PCM is not actually dropping and the previous oil pressure gauge and the fact that my left blinker indicator is out I am thinking I may have electrical issues with the gauge cluster. I have never had these issues while driving in dry weather. Where do I start troubleshooting this? Also I am going out of town for the next two weeks and my girlfriend was going to use the vehicle. Do you think it is OK for her to drive?
Old Feb 20, 2013 | 04:54 PM
greentree ford's Avatar
greentree ford
With the battery light coming on you should check alt.
the stock oil pressure gauge only requires 7 psi
sounds like water is getting in some wear. Do you have overhead lights, sometimes they leak. drivers side sun visor is also know to leak at the mounting screw
sittinguy
Aerostar
Jun 21, 2018 06:35 PM
74Mav
Modular V10 (6.8l)
Jan 1, 2018 09:23 PM
Redneckrucker16
Apr 8, 2014 10:28 AM
MikeB 88
1997 - 2003 F150
Sep 24, 2007 07:41 AM
RA81222
1978 - 1996 Big Bronco
Apr 21, 2007 01:47 PM
