Texas Chapter Join Chapter, Leader: LibTimothy
Lincoln Navigator
Old 03-06-2013, 05:46 AM
blughost's Avatar
blughost
blughost is offline
Lincoln Navigator
I have a 98 Nav and it starts great with no problems. The only thing is it stalls while idling and i know its not the transmission or the relay. What are my options?
Old 03-06-2013, 06:49 PM
DRRXR's Avatar
DRRXR
DRRXR is offline
Guess and a wild one- if there is no check engine light then I would guess the IAC. That would be the easest of problems to fix.
Old 03-06-2013, 11:01 PM
Snuggyworm's Avatar
Snuggyworm
Snuggyworm is offline
sounds like the butterfly valve, or IAC. idle air control? yeah, if tat thing is dirty inside or u gots a leak, then it'll affect ur idling and ur gas mileage too. i remember this cos i helped replace that butterfly valve on a crown vic. if the sensor or motor is out on the butterfly valve, i think there is no part for tat. u might have to buy the whole butterfly valve. but clean it up and see if it fixes the problem first.
Old 03-06-2013, 11:03 PM
Snuggyworm's Avatar
Snuggyworm
but if u do have a check engine light, go to o'reilly's or autozone to scan for the code. with the code, it's much easier to pinpoint the solution to the problem.
scoopyg
Modular V8 (4.6L, 5.4L)
03-28-2018 05:05 PM
thefnswits
1999 to 2016 Super Duty
01-23-2009 07:38 PM
kennyhimself
01-09-2008 12:59 AM
TennesseeGuy
1997 - 2003 F150
06-08-2006 03:31 PM
mbordeaux
1997 - 2003 F150
11-23-2003 11:00 PM
Quick Reply: Lincoln Navigator
