More roadblocks to modifications
I was just looking at an auto tech website, and they were discussing suspension/wheel/brake changes.
The gist of it was that there will be restrictions on on what you can do in these areas due to all of the stability control electronics. Apparently, some of it will be federally regulated. Could include such things as upgraded brake pads.
The out that they were discussing was a certified 'kit' -- much like the emissions certified performance devices. ( I think that that's still required).
Not entirely convinced about stability controls myself, but somebody is.
hj
Preliminary Results Analyzing The Effectiveness Of Electronic Stability Control (ESC) Systems
2010 paper cites several studies, all pointing to good results with ESC:
http://www.iihs.org/research/topics/pdf/r1139.pdf
Those things are hard to wade through, but eventually the numbers show up in black and white.
There have been a few threads on here where lifts have goofed up ESC. Seems like there is a way to reset the computer to the new heights and roll centers. Maybe.
Complicates things, that's for sure. Hard to argue against fewer dead people though.....
Several things do bother me
1. At some point your vehicle changes behavior in an unexpected manner.
2. I don't know that all systems function in the same manner
3. Descriptions in tech areas lead me to think that these are complex and precision systems -- not sure what will happen as they age.
4. No emergency override in some cases. I'd like to be able to blow it off if I thought that was the right thing to do. It would be OK with me if there was a record of that.
5. No standardized performance test available to the normal consumer ( that I know of) to make sure that the system is working correctly.
Anyway, thanks for the informed response.
hj
To me once we've learned how a particular vehicle's chassis dynamics apply we're probably better able to control things much better than a non-enthusiast can in an overly-equipped whatever. We understand what might happen, prepare for the worst case scenario and drive accordingly. Who here doesn't constantly check their mirrors, even on an empty road? That's just one great example.
I want full manual control over most everything----makes me feel in control and not just pointing a computer down the road at 65 MPH weighing 7800#!
Plenty of people, including me, have pulled out into traffic quickly and the car thinks you're getting out of shape so it kills fuel... right after you pulled out in front of someone. Pretty lame. I either give the button the double-tap to go sport mode if it's cold out, or hold the button for five seconds with foot on the brake and clutch in normal driving weather. I'm used to the car for the most part now that I've got 25,000 miles on it, but I still do the first session at a track in Sport Mode. Oh and you can confuse the system on a huge sweeping high speed freeway on-ramp. It'll start stabbing at the brakes a little. Weird. Another reason to turn it off. Funny story, my friend bought a 2011 GT500 and couldn't do doughnuts. He was freaking out when he brought it right back to the dealership. They showed him the system and his panic attack subsided.
Sport Mode allowed my friend to get a little out of shape around turn 6 at Laguna Seca IN MY CAR.
And for the record, I just put Ford Racing lowered springs from the Boss 302S race car on mine and there's no issue with compatibility. Even if I go to other adjustable struts there's no issue with today's car. Tomorrow might be different though.
Oooooh nice spring compressor Kevin!!!
Also had a chance to double tap the button on the ultra rare GT350 in the middle here. The owner hadn't driven a Boss so I threw him my keys. He threw his back!
I gotta get me one of these 624 HP bad boys !
