'72 F-700 Engine Code?
Old May 30, 2003 | 10:32 PM
bigdump's Avatar
bigdump
What engine is the 'B' code for '72 F-700? VIN F70BVP70402
Old May 30, 2003 | 11:29 PM
Mil1ion's Avatar
Mil1ion
Does a 300-I6,sound right ?
Old May 31, 2003 | 02:44 PM
bigdump's Avatar
bigdump
No, It has a V-8, 5 speed manual w/elect 2 speed rear axle. GVW is 23,000. From what I can find F70BVP70402 decodes:
F70=F-700 Series; B=Engine Code (??); V=manuf @ KY Truck Plant; P=1972 year model; 70402=rotation number. Story goes that it was originally a referigerated food truck w/dual fuel engine (propane/gasoline). Converted to dump body w/PTO and hyd hoist. Propane regulator and Pre-heater? still installed although non functional. Porpane piping is all there up to tank connection (Propane tank removed). I'm fixing to buy it as a companion to my '47 Ford Heavy Duty dump truck. May sell '47 flat head dump later on?? Anyway, now you know as much about it as I do. Did Ford make a F-700 dual fuel V-8 engine for '72? Have I misread the engine code?
Old May 31, 2003 | 10:06 PM
Mil1ion's Avatar
Mil1ion
Maybe the engine was changed ?
I just bet that is 361 engine.
Have look in the top of the page *sticky thread* in this forum.
It should be in there.
Here is what ONE Vin decoder states.
Results for VIN#: F70BVP70402
Model Year: 72
Series: Unknown, Please double check VIN#
Engine: 6 Cyl, 300ci (4.9L) 1bbl
Assembly Plant: Kentucky
Transmission: No code selected
Front Axle: No code selected
Rear Axle: No code selected
