are these located correctly ? each head (mirror casting) has a oiling galley. The odd ball rocker stand bolt belongs in the stand boss with an oil galley.
Ok, I understand the part about the heads and oil gallery, but how different are t he bolts supposed to be? Would you possibly have. Picture to help me see what you mean? Thanks, Alex
Hi Alex, the only thing I know to try would be to put in shorter push-rods. When a motor is rebuilt sometimes the head and block get shaved and a stock length push-rod is too long. Take one of yours to a machine shop and haven them get you a few that are 0.060" shorter and see if they help.
I just checked the bolts and they are all in the right place, and the block hasn't been decked so thats out. When it runs the backfire is mostly intermittent, almost like something is moving?
Ok, the test results are in and i think we have a winner:
cylinder 1- 90
cylinder 2- 80
cylinder 3- 85
cylinder 4- 90
cylinder 5- 85
cylinder 6- 90
cylinder 7- 90 cylinder 8- 67
On top of that i can not rocke the rocker arms at all on that cylinder, like the lifters will not pump down and collapse.
Well there may be other issues at hand here. I disconnected the plug wire for the #8 cylinder and the popping did not stop so im at a loss again. Is there anything else that could cause this? A timing chain being off? My new carb being junk? Im an idiot?
Trying to help but over the interwebs without a hands on everything is almost a guess. Did you try removing one plug wire at a time to see what cylinder is popping? Who put the plug wires on?, maybe they are on the cap clockwise rather then counter or the other way around. But if it ran ok a year ago , and the only change you changed was the carb, thats still a possibility..
Yeah, I know it hard to diagnose stuff this way, I'm just annoyed that ite being so difficult. I have checked the plug wires and they are in the right places, and I started doing the one plug at a time thing but haven't done them all. Could a failing ignition box do this? I just remembered I borrowed the nos one I had before to convert another truck and put a used one back on this truck. Thats the only other part thats different it didn't run great before, but that was a timing issue and it wasn't backfiring like this. Thanks again, Alex
Can't help with the ignition box, I've never dealt with them and have never had one, but I guess that's possible too..
Well now we are on a weather hold until the snow quits but im getting a new box to test once i can get the battery back (i have to share the battery and ignition box with the plow truck for now) Heres hoping its the box and the two trucks just have different wiring that wont share the same box.
Well we're back at this with no improvement. I checked the timing chain to see if the kid that did the work years ago messed up, but the chain looks new and the marks line up right. While at it I measured the stroke, about 3 3/4 so its a 390 for sure. Could a crack in the manifold cause this? We're not entirely sure whether it is good or not so if it is cracked could that make it run this way?
Another stab in the dark but are you sure the carb base and the manifold spacer are compatible and there isn't an air leak around the pvc port or somewhere else. You should be able to spray some WD40 around the carb and and manifold while it's running and see if there is a change, same if you think the manifold may be cracked.
Hi Alex, I was re-reading your first post and you said you set the distributor to zero degrees? It needs at least 8, maybe 12 degrees of (initial) advance to run well at all, and vacuum advance is pretty critical.
A real bad vacuum leak could cause issues, but that sounds like a bad leak, something like the brake booster.
Also, when checking for vacuum leaks WD40 works, but carb cleaner works better (it's a bit more flammable)
