C6 problems up shifting
Old Feb 17, 2013 | 03:09 PM
smokietb's Avatar
smokietb
Question C6 problems up shifting
Hi all. First timer here. Picked up an 87 f250 extra cab, long bed, 6.9, c6, ford 10.25, a couple months. It runs strong so I have been ironing out the wrinkles.
Since purchase it will only hit 2nd gear above 25mph and only if i completely let off the gas, and 3rd gear above 45mph again only completely off the gas. I since have installed a new modulator on the trans. Have also played with the set screw position and the best I can get is, with the set screw completely removed it shifts same as it always has. If I run the set screw all the way in I have to be above 30 to get 2nd and can even get 3rd.
I seem to be getting good vacuum at the modulator though I don't have a gauge to really know. Is the vacuum supposed to increase with the RMPs? What should the vac be?
So now i'm thinking the VRV on the IP. I dont see any obvious adjustment. Is it just an R&R? There must be some sort of adjustment.
Thanks,
Old Feb 17, 2013 | 04:56 PM
smokietb's Avatar
smokietb
got my hands on a vac gauge at my pump pulls 25. I have 25 at the VRV on the IP and only 4 at the modulator. if i give it any rpm the vac drops to 0. Does that sound right?
Old Feb 17, 2013 | 05:25 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
you need to set the VRV, or maybe replace it.
your problem is that you are not getting vacuum to the modulator .
here is the instruction for setting the VRV.
https://www.ford-trucks.com/forums/s...6&postcount=12
Old Feb 17, 2013 | 05:31 PM
Twistedwrench's Avatar
Twistedwrench
http://www.thedieselfiles.com/Ford/C...c%20tranny.pdf
The adjustment is in that file .
It doesn't take much to get the shift points where they need to be .
On my injection pump I took the phillips screws out and put hex head bolts in so the VRV is easier to adjust .
Old Feb 17, 2013 | 05:51 PM
smokietb's Avatar
smokietb
thanks guys. its the vrv. with it adjusted to max, i get about 8". took it for a drive after maxing it out and at least now I can get to 3rd at 35 if i let off the gas. Much better then taking it to 45 before shifting. If there is any hill or load though it will almost immediately down shift until i get to 45 and then it will keep 3rd. On that run the set screw in the tany modulator is completely backed out. That was the only way i could get it to shift up.
If im understanding this correctly I need more vacuum to make it shift sooner and to turn in the set screw on the trany modulator to keep it from downshifting on me??
Thanks again!
Old Feb 17, 2013 | 06:00 PM
Twistedwrench
Thanks again!
Try and check the output of the vacuum pump , make sure it's making at least 20"
Old Feb 17, 2013 | 06:27 PM
tjc transport
i ain't rite
Thanks again!
correct.
also, if memory serves correct, you need a green stripe modulator for the diesel C-6
Old Feb 17, 2013 | 06:45 PM
smokietb's Avatar
smokietb
Originally Posted by tjc transport
correct.
Is that a Brand or type? I just got one on line. Looks identical from the outside as the one I had. since putting it on though it down shifts with less throttle now. and if i turn the set screw in to try to make it hold a taller gear under more throttle, i cant get 3rd gear. I'm hopping that gets fixed with a new VRV.
I shouldn't need to turn down my vacuum should I? All the spec say 20". I'm getting 25 at the VRV. Could that be hurting the valve?
Sorry for all the questions. This is my first Auto trans Ever.
Old Feb 17, 2013 | 07:14 PM
Twistedwrench
You want 18" or so at the VRV , as you open the throttle the vacuum should drop , full throttle should show about 3-0" .
On the vacuum modulator put the screw in 3 turns .
I'm saying 18" going to the vacuum modulator from the VRV
Old Feb 17, 2013 | 07:15 PM
tjc transport
i ain't rite
at least 20 inches vacuum. over is fine, because you will compensate with the VRV.
25 sounds like a new pump.
minimum vacuum needed at the VRV is 17 inches.
green stripe is on the modulator. there are green, black, white, and i believe purple. the black, white, and purple stripes designate different sea levels for gas engines, and the green is for diesels.
at least this is the way i remember it from the last time i messed with one 10 years ago.
my 88 would not shift worth a damn when i first got the trans. an old time trans guy gave me the heads up on the different modulators. i popped a green stripe in and reset the VRV and it has been golden since.
Old Feb 17, 2013 | 11:10 PM
smokietb's Avatar
smokietb
Any recs on an VRV. hit the usual suspects. Rockauto, jegs, LMC, plan old google shopping. Not finding much.
Old Feb 18, 2013 | 08:46 AM
tjc transport
i ain't rite
ford dealer or international dealer only. that is not a parts store item
Old Feb 19, 2013 | 08:14 AM
smokietb's Avatar
smokietb
So i picked on up from an injection shop near me. Don't know why i didnt think of them sooner. they gave me a known good used one for half what a new on would of cost me.
Works like a champ now! I ended up setting the vac to 16" at idle and two turns in on the trans modulator. So it shifts early and wont downshift unless you really get into it.
Thanks for the Help Guys!!
Old Feb 19, 2013 | 09:07 AM
Twistedwrench
Cool glad you got it going
_Trekker
15
Jul 20, 2019 06:59 AM
Chris Ko
May 13, 2017 10:23 PM
dieselutheran21
37
Sep 2, 2014 08:04 PM
cleanLX
Feb 6, 2005 02:43 PM
JoeF150
Feb 27, 2003 02:56 PM
