Sponsored by: Real Truck
Harley Davidson Headlight mod problem...
Old Feb 17, 2013 | 02:04 PM
Gage2502's Avatar
Gage2502
So I did the Harley Davidson headlight mod to my truck last and before winter came I wanted to see if they where sealed good so I pressure washed my front end and sprayed the headlights really good and I didnt see any leaks. The other day I noticed that when I have them on the is fog on the bottom corners of them. I dont know if I should take them out and seal them again, or someone told me to drill a small hole 1/8? and fill them with compressed air like 20 psi and find the leak. Than I read somewhere that these lights might be vented?
Also I was told that maybe if I drill a few holes in the rear bottom that it would not fog up anymore?
What do you guys think?
Thanks....Gage
Old Feb 18, 2013 | 02:10 PM
Gage2502's Avatar
Gage2502
Anyone have any ideas?
Also The fog will go away in a few hours after I turn the lights off.
Old Feb 18, 2013 | 03:28 PM
mikeismadness's Avatar
mikeismadness
I'd check your seals. Dodges were known for this problem 94-01, and they had the horrid issues with lens cracking and terrible seals. The slightest crack or seal issue will cause head aches
Old Feb 18, 2013 | 04:06 PM
2ndStroke's Avatar
2ndStroke
Must be the seal, I had a bad seal just around my bulb once that gave me all sorts of moisture problems, siliconed around the bulb and never had any moisture inside the headlight again. What did you use to reseal your headlights?
Old Feb 18, 2013 | 04:47 PM
Gage2502's Avatar
Gage2502
This is the sealant I used....
Sealants : Permatex® Black Silicone Adhesive Sealant
So the headlight bulbs are newer, thinking that since the "fog" is on the lower part of the headlight Im thinking the lower marker light sockets are faulty? What do you think.
Thanks....Gage
Old Feb 18, 2013 | 05:13 PM
2ndStroke's Avatar
2ndStroke
Ok, I used the same stuff to seal my headlights about 8 months ago, they are still good. I installed hid bulbs, a few weeks later or so i had the foggy headlight, so I guessed that the seal was bad and siliconed all around the base of that bulb. Never had moisture problems again, maybe try that first??
Old Feb 18, 2013 | 05:38 PM
Gage2502's Avatar
Gage2502
Thanks...I will try that first, I have to wait till it gets warmer, because I dont have a garage for my rig =(
Do yo have a bigger picture of your truck looks really good, I dont think I ever see that paint combo before on the newer trucks.
Thanks...Gage
Old Feb 19, 2013 | 05:01 AM
2ndStroke's Avatar
2ndStroke
Thanks...Gage
Ah that sucks, I'm garageless right now too. Hopefully that works, I dunno about drilling holes.
Thanks, I don't think I've seen this paint combo in person either now that you mention it.
joey schaffner
2009 - 2014 F150
Nov 28, 2012 08:08 PM
Downriver Thunder
Dec 5, 2008 09:10 AM
myEXisFAT
Dec 2, 2006 11:04 AM
MG94
2004 - 2008 F150
Aug 21, 2006 07:33 PM
SoConSick
2004 - 2008 F150
Jun 6, 2005 06:22 PM
