2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
How do you check trans fluid on 2008? Flush?
Old 09-13-2011, 08:04 AM
2000F2504X4's Avatar
2000F2504X4
2000F2504X4 is offline
Our 2008 Expy is close to 100k miles. I have noticed the transmission doesn't seem as smooth. I am ready for some new fluid, but can't find the dipstick or anything related to the trans. Is this a sealed unit? Can I have it flushed using the cooler lines? What is the proper maintenance for this trans? I have the 5.4L.
Thanks,
Old 09-13-2011, 12:41 PM
berry1234's Avatar
berry1234
berry1234 is offline
There is no typical dipstick. There is a plug on the transmission itself on the passenger side. Attached to the plug is a sort of small dipstick. I would avoid all Jiffy lube type services like the plague and take it to the dealer you trust. I would have them change the filter and exchange all the fluid out.
Old 01-08-2012, 09:39 AM
jims91's Avatar
jims91
jims91 is offline
I dropped the trans pan on my wife's 2007 Navigator, with 36,000 miles on it. The navigator has a type III hitch and towed a car trailer for about 60 miles. We purchased the navigator new with 35 miles on it.
The 2 magnets were about 1/3 to half full and pan was clean. My wife commented on how the removed fluid was dirty (4.5 quarts) when compared to the new fluid. Had daughter do search of places with the new Mercon SP fluid as Oreillys did not stock it. Winchester auto (10 miles away) had Motorcraft Mercon SP at 6.50 a quart. The fill plug is on the passenger side (similar to manual transmissions) There was no dipstick on the plug. Cleaned differiential oil pump and container and pumped in 4.5 quarts of trans fluid. The trans pan gasket is re-usable.
Based on this, I would recommend the pan drop at 100K to clean the magnets and replace the filter. However, I would recommend a trans fluid flush (pump-out) at 50,000 for vehicles with tow usage.
Also dropped the trans pan on my '99 ranger pickup with 48,000 miles which was my father's vehicle. Pan was coated with the black muck and I cleaned the small magnet. Replaced filter and it only took 4 quarts Mercon V.
Based on previous experience and these experiences, the 6 speed trans used in the 2007 and up expeditions and navigators are not generating the amount of magnetic particles as the previous transmissions did.
Jim
Old 02-15-2013, 09:04 PM
drewworm's Avatar
drewworm
drewworm is offline
Transmission service and flush.
A Ford dealer I spoke to didn't seem sure if a service interval was recommended for my 2008 Expy. Odd right? He did say if it was something I wanted to do that it would be really expensive. Boy, that is really helpful information. Thanks Ford.
Kris70
1978 - 1996 Big Bronco
01-12-2019 04:09 PM
Gage2502
1999 to 2016 Super Duty
36
02-12-2015 04:06 PM
Truckie256
03-09-2014 07:41 AM
fordcrzymike
Escape & Escape Hybrid
06-06-2013 11:52 AM
Stoogefan
01-23-2007 08:52 PM
Quick Reply: How do you check trans fluid on 2008? Flush?
