Just doesn't look right
Old Feb 13, 2013 | 11:20 AM
Haulnkarts's Avatar
Haulnkarts
I am in the final stages of completing my head gasket, egr delete, oil cooler project and I’m to a stopping point. In the removal of the oil filter stand I removed all three screws and did not pay much attention and now I'm stuck. I cannot remember exactly how to re assemble the anti-drain back and oil cooler bypass assembly as far as where the spring goes. I assumed that it goes under the anti-drain back valve but it just does not look right in how it just sits on top of the base below. Am I missing something here, all I have is the spring, bracket with the valve and the mounting screws. Thanks for your help
Old Feb 13, 2013 | 02:35 PM
mustang_309's Avatar
mustang_309
I haven't had my truck apart that far yet, but the spring should hold the valve up so it is open the filter is not sitting on it.
Old Feb 13, 2013 | 02:53 PM
mustang_309
Here is a link to a srmastertech video, and at about 8:50 in the video it shows a pretty good shot of the valve you are talking about. You will note in the video he doesn't actually remove the drain back valve or at least that I saw.
hope this helps.
Old Feb 13, 2013 | 05:40 PM
Lilpooh's Avatar
Lilpooh
Does this help.
Old Feb 14, 2013 | 07:50 AM
Haulnkarts's Avatar
Haulnkarts
Thanks for your help guys. I found my oil cooler bypass valve in the parts washer under the strainer. Put it together last night should fire it up tonight and do my check out.
Old Feb 14, 2013 | 09:55 AM
dannyboy950's Avatar
dannyboy950
Nice pics, but what is all that flakey looking stuuf??????
Old Feb 14, 2013 | 12:47 PM
Lilpooh's Avatar
Lilpooh
They were extra housings I had laying around from past projects, so they sit in the corner of the garage collecting dust/dirt.
Old Feb 14, 2013 | 03:55 PM
dannyboy950
kinda what I thought, looked like shelf debrie stuff that gets bllown around in a shop.
Old Feb 14, 2013 | 04:35 PM
BLADE35's Avatar
BLADE35
I dont take mine apart Like that the Oil Filter Housing that is
Just those 3 main housing bolts but leave all the Valves and drains and stuff In Tact and Pull the Housing as a Unit Out
Make shure you roll the engine By Hand before you Fire it up the first time
I dont know why but sometimes it will bend the Pushrods
I think somehow they stay Pumped Up and is common to Bend a rod that first crank
Cheezit is the guy to ask all the specifics on this
All I know is if you roll it by hand a couple times you will AVOID This
joelewis73
Dec 16, 2014 11:09 PM
jswartz84
Mar 19, 2013 01:19 AM
redman84
Apr 23, 2012 08:52 PM
firebug
Feb 29, 2008 09:39 PM
