Sponsored by: Real Truck
5.4 power improvement
Old Feb 14, 2013 | 12:13 PM
Buck268's Avatar
Buck268
Originally Posted by Garymcd
Yes that is for one axle only. I was not aware the speedometer read off the ring and pinion gear. I will check into that. The $1500 is a high estimate. Gars are about $450, install 6 hours at $95 per hour(about 600), oil and extra BS supplies that they will charge for I figured another 200 plus tax. comes to around 1500.
Sounds very high for labor, at the least.
Old Feb 14, 2013 | 12:51 PM
SuperDutyScaler's Avatar
SuperDutyScaler
i had a 4x4 shop install factory OEM 4.30 gears, timken bearings, a rebuild kit for the crappy factory LS plus labor, i paid $2,300.00 cash for the job and i got a lifetime warranty on paper...
Old Feb 14, 2013 | 02:09 PM
ChrisAU's Avatar
ChrisAU
Is your truck 2WD or 4WD? If it is 4WD and you only regear the rear axle, then you have effectively lost 4WD. You will tear up all kinds of stuff if you were to put it in 4WD.
Old Feb 14, 2013 | 02:18 PM
wizkid00104's Avatar
wizkid00104
For $2300, I would've figured out how to do it myself. No offense, but I have a serious issue with paying for labor because I always seem to get bent over the counter in the end.... If they don't screw me on price, they screw me on quality.
As an alternative to paying for gears, you may be able to find axles for sale on craigslist with the gears you want already in there. Its an "easier" install be cause it isn't so precise and you could realistically do it yourself with only paying for new U-bolts. This is a very common occurrence in the Rangers I dabble with.
Old Feb 14, 2013 | 04:26 PM
maverick22's Avatar
maverick22
Keep in mind that cost was for both axles, I would guess w/ factory gears 1/2 - 3/4 of that price was just parts. Regearing isn't rocket science but nor is it something you want to tackle w/ no experience - you can destroy your brand new expensive gears if it's not set up properly. It's a very precise job and you need the proper tools.
Swapping axles is an option, but he's got a 2006 so he can only look at 2005 and up, those are more expensive to start with and if he has 4x4 then he needs to find front and back that are geared the same. Not sure you would save much.
Old Feb 14, 2013 | 08:36 PM
Bigpipes 35's Avatar
Bigpipes 35
That sounds about right, I was quoted 2800 at the ford dealer and 2400 at a private 4wd shop,,,,
Old Feb 14, 2013 | 08:49 PM
ChrisAU's Avatar
ChrisAU
I have a guy that will do it for $300/axle if you bring him the parts. If anybody is in the Birmingham, AL area let me know and I'll send you his info. He does a good job and was recommended to me by my trans shop and those guys have an excellent reputation locally.
ford ratt
Jan 25, 2018 07:08 PM
RentAMan
Modular V8 (4.6L, 5.4L)
13
Feb 17, 2011 02:02 PM
pds00
Jan 11, 2011 05:45 PM
Wayne64SS
Oct 11, 2010 07:19 PM
Powerstrokin_350
Sep 5, 2009 12:04 AM
