I`ve forwarded this on James, I still suggest you log out and delete your cookies to see if it helps.
I still suggest that it doesn't happen on the other sites that I visit
We've bee thru the FTE doesn't have a problem thing many times before
I'm not going hunting thru the HTML again just to prove a point
Right now we're having a problem with one of the database servers, and we're running on a spare. Admin is going to do a fix around 8:00 pm Pacific time that should fix the problem.
What where you trying to access when you got that message? Is it a particular thread? A particular forum?
To answer the question, there's no real rhyme or reason. I typically only visit this bunch of misfits, so this is where I've found the problem. It's intermittent and can occur clicking on a thread or coming back to the main forum page. While the new page is loading it suddenly redirects to the address in the link I provided. This morning it did it at my initial visit to the forum for the day. That's when I copied the addy and started the new thread.
Right Now? The Data Base Error message has been occurring sporadically over the past 5 weeks.
If you're online, sometimes you can back up, refresh and then continue, sometimes...you cannot. Sign off, try it again in about 15 minutes, usually can sign back on.
Early this morning, at 12:15 -12:30 PST, I attemped to sign on, got the Data Base jazz over and over again...finally gave up.
I had the problem again last night. Refreshing didn't help. Closing the window and clearing cookies didn't help either. Finally got the homepage to sort of load. Here is a screen shot of what the page looked like. After that I gave up for the night, which wasn't a bad thing...it was past my bedtime!
And to back up Bill, it has been going on for weeks.
