Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Temp control cable
Old Feb 11, 2013 | 09:55 PM
fivestarmmd's Avatar
fivestarmmd
Temp control cable
Have 83 F800 still looking for correct cable. Have E3TZ18518B which is not the rite cable. The orginal has tabs for screws on both ends. Build date of unit is 3/83 and is a bid unit i/e old state truck.
Old Feb 12, 2013 | 10:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by fivestarmmd
Have 83 F800 still looking for correct cable. Have E3TZ-18518-B which is not the correct cable. The orginal has tabs for screws on both ends. Build date of unit is 3/83 and is a bid unit i/e old state truck.
Look at the original cable, see if there's an ID number marked on it, if so, post what it is. If your truck has factory A/C or Hi/Lo Comfort Vent System, the temp cable is different.
E3TZ-18518-B .. Heater Temperature Control Cable / Marked: E3TH-18D306-AA or AB or AC / 1983 F100/350 & Bronco / 1983/86 F/FT600/900.
Are you sure you need the temp control cable? There's another: E3TZ-18552-A .. Heater Air Control Cable.
Old Feb 12, 2013 | 09:01 PM
fivestarmmd
Temp control cable
This unit does not have A/C. Wish did the turbo generates a bunch of heat. This cable moves a door in heater box that diverts air thru heater core or as fresh air into cab. The ID number tag on cable is gone and cable hsg is badly deterated. Thanks for help. Need to find someone that has one.
Old Feb 13, 2013 | 02:59 PM
NumberDummy
The ID number tag on cable is gone and cable hsg is badly deteriorated.
The ID number (not the part number) is printed on the cable itself. See post 2 for the ID numbers of the temp cable.
There are only two cables, if E3TZ-18518-B is wrong (if you're sure that's what it is), it has to be the other cable.
E3TZ-18552-A .. Heater Air Control Cable / Obsolete
TALLAPOOSA FORD in Alexander City AL has ONE = 256-234-3432.
CARPENTER NOS OBSOLETE PARTS in Concord NC has ONE = 800-476-9653.
NOS ONLY in San Jose CA has TWO = 800-667-6659.
E3TZ-18518-B =
BLOOMER FORD in Bloomer WI has ONE = 715-568-2182 / No one else has any.
Ask for descriptions, measurements, before you buy either of these puppies.
joe4law
Feb 17, 2017 11:59 AM
Aynor90
Jan 19, 2015 02:34 PM
fivestarmmd
Large Truck
Jan 9, 2013 04:58 AM
bobpfister
13
Oct 2, 2012 05:08 PM
72bronc
Jan 14, 2009 11:56 AM
