2006 F150 how do i know if there is a lift kit in my truck
You would be better served if you post in the proper forum .....------------------------------
-click- the pic'
Goth 150
< This space intentionally -blank- >
2004 - 2008 F150 - 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
Rather than ...2009+ F150 - Discuss the 2009, 2010 and new 2011 Ford F150
-click- the pic'
Goth 150
My stock 2009 F150 has a block that looks to be rubber and is about 1" thick between the rear leaf springs and the axle perch. Rear blocks larger than that would probably be from a lift kit. Look at the front springs and see if there are any spacers on top of the coil springs.
Otherwise try to find another truck to park next to and compare the height of the wheel well openings.
95xltmud
12-13-2002 08:16 PM
