My wife took our 94 Arrowstar last night and the interior lights would not go out. I looked at all of the obvious items like the dimmer switch and all of the doors, but nothing. The door ajar light does not come on yet it is acting like a door is open. The lights are designed to come on when you pull the door handle and turn off after a while or after you turn the key.
Any suggestions would be great. At this time I pulled the #8 fuse but that also turns of the speedometer & radio.
You have a closed circuit somewhere. Look at the doors and rear hatch and see if one is bad. Just remove one at a time and unplug it till the lights go out..
I found the problem. I was looking around all of the doors and found the button for the side door was missing. I asked my wife about it and she said OOOOh, thats were that black plastic came from.
Needless to say I took the old switch out and unpluged it, and I have to go get a new switch.
Thank you for your help and I will most likeley be back some time in the future with other problems.
