Highboy Wheel Sizes
Old Feb 5, 2013 | 02:03 PM
cysneed's Avatar
cysneed
Highboy Wheel Sizes
Hey boys, just wondering if anyone could tell me if a 15" wheel would fit on a factory highboy or not? Anyone tried it? Thanks, I appreciate it.
Old Feb 5, 2013 | 08:12 PM
76FBB's Avatar
76FBB
15's will not fit. I have a 76 f-250 highboy and my spar tires on 16's barley fit. If you have the dual piston calipers in the front I don't believe they will.
Old Feb 6, 2013 | 04:15 AM
Xauterus's Avatar
Xauterus
They will fit if you have bugger all back spacing. My truck came with 15x8 wheels but they had less than 3 inches backspacing to clear the dual piston calipers.
Much better with 16 inch wheels.
Old Feb 6, 2013 | 04:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
High Boy: Enthusiasts term for 1967/76 F250 4WD's, 1977 F250 4WD's assembled before serial number Y20,001. Have a divorced transfer case. No such thing as an F100, F150 or F350 High Boy.
No F250 2WD or 4WD came from FoMoCo with 15" wheels, as there was no such thing! / 5 lug 5.50" bolt circle 15" wheels only installed on F100/150/Bronco thru 1996, 1975 thru today E100/150's.
All 1953/98 F250's came with 8 lug wheels on a 6.50" bolt circle. 1953/66 F250's came standard with 16" wheels, 17.5" x 5.25" and 19.5" x 5.25" wheels were optional.
All 1967/98 F250's came with 16" wheels. 1967/79 F250 Camper Specials came with unique 6.75" x 16.5" wheels that required special tires that were hard to find and expensive when found.
Old Feb 16, 2013 | 08:57 PM
Xauterus's Avatar
Xauterus
Mine was fitted with aftermarket wheels. I think you call them wagon wheels? The white steel spoked wheels.
Old Feb 17, 2013 | 09:06 AM
spikinfool05's Avatar
spikinfool05
depends on what year of highboy it is. i had a 1976 for awhile that had 15s. the back of the rim was flush no back spacing at all. on my 74 i have currently 15 slot mags fit but it has drum brakes. as for factory bill is right on the money as always. only thing is i think most had 16.5. at least that is my experince with the trucks.
Old Feb 15, 2021 | 09:48 PM
MustangSal's Avatar
MustangSal
F 250 Wheels
16 I’ve seen on HD or 4x4
lambchops25
20
Aug 23, 2020 03:28 PM
notacharger
Oct 13, 2016 05:53 AM
packard8
May 20, 2012 02:05 AM
jgreen
Sep 13, 2006 09:13 PM
bmjwright
Nov 10, 2005 02:09 PM
