brake problems
Old Feb 5, 2013 | 10:48 AM
dev_jhnsn's Avatar
dev_jhnsn
brake problems
I have a 1995 f250. A couple weeks ago, I did a brake job, all four corners of the truck. Brakes worked great, drove it for a couple days and parked it and went on vacation for a week. When I come home and hop in the truck, the brake pedal falls to the floor. My first thought- master cylinder. Then I turn key, and the red brake light was on, along with my amber abs liight. I check the cylinder and its almost empty, but I topped it off while doing the brakes. Also, when I pump the pedal with the engine off, it doesn't build pressure like the booster has a leak. So I don't know what to condemn. Input is appreciated!
Old Feb 5, 2013 | 11:04 AM
dixie460's Avatar
dixie460
It's gotta be leaking somewhere, have you looked all over? Even inside the stupid drums? Sometimes the fluid leaks out and trickles along the frame or whatever and ends up where you wouldn't expect it.
I'd say since it ran out of stop juice, you got air in the lines now. Refill it, check for leaks everywhere, and fix as needed.
Old Feb 5, 2013 | 11:39 AM
dev_jhnsn's Avatar
dev_jhnsn
I checked over all the lines and fittings and couldn't find any leak, but I never pulled the drum off. I'm confused why the brake booster wont build pressure though?
Old Feb 5, 2013 | 01:37 PM
dixie460's Avatar
dixie460
Honestly I would think if the reservoir was empty, you would see it leaking out of the drums. But it can't hurt to check, stranger things have happened.
The booster won't build pressure as in it won't provide any boost any you have a hard pedal?
Or the pedal goes all the way to the floor as you said in your previous post?
Old Feb 5, 2013 | 01:44 PM
blkF250HD's Avatar
blkF250HD
You have a leak. Brake fluid doesn't evaporate, so it had to have gone somewhere. The master cylinder could be leaking into the brake booster, the wheel cylinders could be leaking into the drums, a steel line could have rotted out, etc. Fill the reservoir and have a helper watch under the truck as you pump the pedal (engine off). If its a line you'll see it begin to spray and drip.
The reason for the soft pedal is you now have air in the system. Air is compressible, fluid is not. The booster only works when the engine is running and supplying vacuum.
GunnerAsch
Aug 1, 2019 06:49 PM
stephenok711
Jun 2, 2012 05:59 PM
agaristo77
1978 - 1996 Big Bronco
Dec 23, 2011 12:58 AM
RTM
May 30, 2005 12:23 PM
msfprobass
Mar 6, 2003 06:35 PM
