Engine pop
Old Feb 4, 2013 | 09:00 PM
earl6969's Avatar
earl6969
Engine pop
I have a 1972 Ford truck with 391 engine. It pops every 4 or 5 seconds while idling but smooths out when driving. Runs smooth until highway speed then seems to start skipping or cutting out. It has all new everything timing, ignition and fuel related. Do I have the points set wrong? I've also been told about the points "bouncing" at higher RPM. Any ideas?
Old Feb 4, 2013 | 09:06 PM
HIO Silver's Avatar
HIO Silver
Sounds like a points problem to me. Have you re-checked them for deep pitting or arcing?
Save your self some headaches and eplace that archaic technology with a Pertronix Ignitor (I, II, or III) ignition module.
Old Feb 4, 2013 | 09:09 PM
SOB Racing's Avatar
SOB Racing
i WOULD PLAY AROUND WITH TIMING FIRST. AND CHECK THAT PLUG WIRES ARE WHERE THEY SHOULD BE. ALSO CHECK FOR VACUUM LEAKS. GOOD LUCK
Old Feb 4, 2013 | 11:11 PM
Redmanbob's Avatar
Redmanbob
Pops through carb ? exhaust? I would check the timing and that the vac/mechanical advances are working correctly.
How old are the valve springs, if they are tired or you have worn seats you could get this issue. If you have a heavy carbon deposit on pistons it can pre ignite the fuel/air mix.
Old Feb 5, 2013 | 12:36 AM
earl6969's Avatar
earl6969
Alot of good ideas. I've thought about and looked at the Pertronix system, but all I find says that it is for marine applications. Anybody had experience with changing over from points to electronic type system?
Old Feb 5, 2013 | 12:37 AM
earl6969's Avatar
earl6969
Oh by the way the "pop" is through the exhaust.
Old Feb 5, 2013 | 12:58 AM
70-360fe's Avatar
70-360fe
Pertronix sold at advance auto and online, got mine off ebay cheap. Easy to install and nice upgrade, engine starts easier and runs better. Plus you don't have points to replace/adjust anymore.
Old Jan 1, 2016 | 10:17 AM
earl6969's Avatar
earl6969
391 misfiring
It's been over a year since I last posted. The sputtering and cutting out has persisted, but I have tolerated it since I rarely get on the highway with this truck. When I first started posting about this problem, Pertronix systems were out there , but I couldn't find anyone who had actually tried it in a 391. H.E.I. ignition distributors were around, but way too expensive. HEI systems are now affordable, but I can't find one for a 391, only 390s which I understand has a different size intake hole and different shaft size. I know there are bushngs for the intake hole problems, but what about the shaft difference.
Old Jan 1, 2016 | 12:22 PM
351Cleveland C4's Avatar
351Cleveland C4
A pertronix kit will run the same in any engine. I highly recommend you pull the trigger and buy one.
Old Jan 1, 2016 | 01:11 PM
CougarJohn's Avatar
CougarJohn
It looks like you have to tread carefully with 390 and 391 distributor interchanges and internals. I found this. It may help you:
Big block ford 390/391 - Hot Rod Forum : Hotrodders Bulletin Board
Old Jan 2, 2016 | 11:56 AM
JEFFFAFA's Avatar
JEFFFAFA
The 391s had an internal governor in the dizzy. If high RPMs are making it loose power it is the governor kicking in. AND there is one thing that hasn't been mentioned yet. The 330 M.D. took the same size oil pump driveshaft in between the Dizzy and the oil pump as a FE motor. The 330 H.D,361, and your 391 takes a bigger diameter oil pump driveshaft.
fuimus1
Sep 10, 2015 09:58 AM
drusher
15
Jul 24, 2014 04:38 PM
F250duke
Aug 24, 2009 04:27 PM
F250duke
Electrical Systems/Wiring
Feb 8, 2005 05:29 PM
Tom Youngblood
Apr 15, 2003 01:50 AM
