I have a Gibson side swept exhaust on my 1996 351w Bronco. Thinking about upgrading the catalytic converters to hi flow cats. Any suggestions? I've heard Bassani y pipe converter is good
Bassani! Im sure youve visited the bronco forum, and have heard all about them. Yes, a high flow cat replacement is ok, but it only solves half the problem. You ever take a look at that stock pipe? Its all creased, and the tubes are tiny. The bassani is all mandrel bent, and is 3" through the cat. Cant go wrong.
Originally posted by Dutch123 wheelMA1 you say the Bassani only solves half the problem what did you mean?
I was referring to Buck000's post. He said that he bought a high flow convertor only. If you dont open up the pipes entering the cat, as well as leaving, youre not optimizing your output.
