1978 - 1996 Big Bronco
blinkers not working
Old May 29, 2003 | 11:05 AM
89broncobob's Avatar
89broncobob
ok my blinkers and my rear defog will not work ..they were working fine i changed the fuse and the blinker thing that makes them blink but still no good .my 4 ways work and my lights work but when i put on my turn signels they dont light up or nothing and help thanks ..it a full size 1989 bronco 351w...thanks you guys are the best ...
Old May 29, 2003 | 09:17 PM
drittler's Avatar
drittler
Are you sure you changed the right "thing thats make them blink"? There are two seperate ones for the turn signals and the four ways. If you turn the 4 ways on you'll here the click click click from the 4 way one. The same goes for the blinkers. If no sound, then thats your problem. I'm not much of a mechanic which if probably evident here but I fixed the same problem on my 91 yesterday. Hope this helps.
Old May 29, 2003 | 09:27 PM
89broncobob
thanks but i found it .there is a rod that runs down the collem .it go.s to a box that starts the truck and supplys the volts to that side of the fuse box.it powerd the rear defrost and allso the ac...i fixed it ..but thanks for the reply
Old May 29, 2003 | 11:46 PM
steve83's Avatar
steve83
That "box" is the ignition switch.
