Just looking for an explination of what makes a straight axle a straight axle and whats differant about a solid axle. searched all over the internet, couldnt ever find out the differance, hell couldnt even find out what IFS stands for!
Thanks
The Ford TTB was a modified form of IFS, still an IFS system though. The F350's from 85.5-97 used a dana 60 solid axle, rather than the TTB the 80-96 F150(coil sprung) 250/80-85 F350(leaf sprung) used. The 97-Up F150's and the F250 LD(looks like an F150 with 7 lug wheels) run an A-Arm IFS, while the Super Duty trucks(F250 HD and up) use a Solid axle with leaf springs, either a D50 or 60 depending on the truck.
Evan
Originally posted by 82F100SWB The Ford TTB was a modified form of IFS, still an IFS system though. The F350's from 85.5-97 used a dana 60 solid axle, rather than the TTB the 80-96 F150(coil sprung) 250/80-85 F350(leaf sprung) used. The 97-Up F150's and the F250 LD(looks like an F150 with 7 lug wheels) run an A-Arm IFS, while the Super Duty trucks(F250 HD and up) use a Solid axle with leaf springs, either a D50 or 60 depending on the truck.
Evan
I'm not positive what you mean by "modified form of an IFS." There are two basic types of front suspensions. A straight/solid axle or the IFS system. There are numerous styles of IFS avalaible from many different manufactures. In a sense they are all modified, as there is no set rule that states what is the one and only original correct version that all would be based off of.
Ford TTB front axles are basicaly a solid axle that pivots in the center that makes it what I call semi-independent. The Caster and camber changes as it compresses and rebounds. The newer 97up F-150's have an upper and lower control arm that keeps the caster and camber in check. I have a 93-f250 with TTB, if your really load it down the front tires lean in. Ford kept it from 1980-1997 F-250s, There is alot of parts available for them and that is a plus to the added tire wear factor.
When looking at solid/straight front axles on Fords, generally the lighter duty models (F-100 F-150) have coil springs and the heavy duty models have leaf springs.
The more durable and easier to modify (read lift) are the solid axles with leaf springs, they provide a lower cost of repair/ownership over the life of the vehicle. Also, they provide the worse ride and handling (they do not feel like cars or minivans).
IFS stands for Independent front suspension. So a TTB is that, because both sides move up and down independently. There's no such thing as modified IFS. Come on, common sense. Some IFS are better than others, but just because the TTB doen't have two control arms doesn't mean it isn't IFS or is "semi" IFS, because both sides still move up and down independently.
