Headlights randomly coming on?
Old 02-08-2013, 09:59 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
If you do find that the GEM has gotten wet... Pull it, let it drain out any from the inside if it has any left..then bury it in a bowl of uncooked rice and tightly cover with saran wrap overnight. The rice will soak up any moisture in it. You may be able to save it. This I have seen a few times as well and it worked.
Old 02-08-2013, 11:34 AM
Yougotthehit's Avatar
Yougotthehit
Yougotthehit is offline
Where is the Gem located? What does it stand for?
Old 02-08-2013, 11:45 AM
BillyBob69's Avatar
BillyBob69
It is located above the fuse panel under the dash.
If I remember right, GEM = Generic Electronic Module
Old 02-08-2013, 12:16 PM
Yougotthehit
Does anyone have a pic of location and or of it?
Old 02-08-2013, 02:47 PM
BillyBob69's Avatar
BillyBob69
I dont have any pics but here are a couple of links that may help with descriptions. It can be a pain.
Hopefully someone else will pop in with pics.
Post #2 & 4
https://www.ford-trucks.com/forums/2...-location.html
Post #2
https://www.ford-trucks.com/forums/9...e-removal.html
Post #2
https://www.ford-trucks.com/forums/8...odule-gem.html
Old 01-14-2014, 11:52 AM
damons's Avatar
damons
damons is offline
Chiming in, I may have this issue, need to figure out as well where the GEM is, we have had heavy rains here recently. I did change the headlights recently, but I tried putting the old ones back in, same thing, stayed stuck on. Not sure if I should throw a new switch on there first and see or what.
Old 01-14-2014, 11:57 AM
BillyBob69's Avatar
BillyBob69
The GEM is the little black box behind the fuse box under the dash.
Old 01-14-2014, 05:00 PM
whitetmw's Avatar
whitetmw
whitetmw is offline
Here is the revised wiring diagram. I would check the wiring first for corrosion at connections, closed to grounds, and insulation detrition. The Low Beams are on separate circuits. One thing you didn't mention is does it have DRL's? This adds a little to the mix because there is also an Exterior Lighting Module which, when malfunctioning can do the same.
Old 01-14-2014, 07:26 PM
damons's Avatar
damons
damons is offline
Ok, it's probably not the headlight switch, plugged in new one, headlights are still on, they headlights are even on when switch is unplugged. We checked all known fuses.
Dead end....
1968 F100 Ranger
21
01-25-2015 03:53 PM
dpty22
03-10-2013 12:54 PM
rich51fordtruck
01-07-2007 09:49 PM
69crewcab
10-19-2003 09:52 PM
SafewayPete
02-27-2003 01:54 PM
Quick Reply: Headlights randomly coming on?
