Knock, Knock
Old May 29, 2003 | 09:33 AM
MrScary's Avatar
MrScary
Knock, Knock
Hello, guys! Newbie here!
I have a 1988 F-250 4x4 with a 460. I just started hearing a knocking in the motor. I had a local garage put it up on a hoist and listen and the mechanic said the knock was coming from the oil pan and was probably a rod and the engine should be rebuilt/replaced. Maybe a dumb question, but could a crank/rod/piston (whatever is causing the knock) be replaced by dropping the pan without removing the motor? I know it wouldn't be an ideal fix, but its an older work truck and probably not worth as much as a new motor!
Also, I have run across a couple of used or rebuilt 460s that are mid 70's motors. If I replace this engine completely with an older carburated model, what do I do with the computer? Can it simply be disconnected and the truck still run properly?
Thanks for any info!
Old May 29, 2003 | 11:07 PM
c_rossman's Avatar
c_rossman
Knock, Knock
put a real oil pressure gauge on the motor. If a main bearing or rod bearing is out it would have pretty low pressure. If it is a wrist pin oil pressure wouldnt be affected. you can roll in new bearings by removing the pan but chances are you might do more harm than good. Do you know for sure the knock is at crank speed? you can check this with a timing light. If it is at cam speed it would only happen everyother rev. I have a bad lifter in my 460 that needs attention, maybe this winter i will get around to it.
Old May 30, 2003 | 08:36 AM
KJKozak2's Avatar
KJKozak2
Knock, Knock
Could you explain this statement please? I'm planning on replacing my rod bearings because I know they're all worn.
I just picked up a set of mic's to measure the journals to make sure they're still within tollerance. If they are, and just the bearings are worn, what kind of "harm" could I cause by changing bearings?
TIA.
Kevin K.
Old May 30, 2003 | 09:13 AM
LxMan1's Avatar
LxMan1
Knock, Knock
As long as the crank is within specs, it is ok to replace the bearings. Ususally though, by time it's a knockin, there is at least some minor crank damage that will require turning the crank.
Jimmy
Old May 30, 2003 | 09:27 AM
KJKozak2's Avatar
KJKozak2
Knock, Knock
Thanks for the clerification.
Kevin K.
