Overheating Issue
Old Feb 11, 2013 | 12:56 PM
BigBlockMan's Avatar
BigBlockMan
are you losing water? Those were bad about cracking heads.
Old Feb 11, 2013 | 01:17 PM
Filthy Beast's Avatar
Filthy Beast
Originally Posted by thagoldenb
I'm not exactly sure but I don't think I have a fan clutch. Correct me if I'm wrong as I'm new to all this. Here's a pic I just took.
Correct - no clutch fan. Shroud looks ok. From the picture, your radiator bottom looks a bit rugged - any corrosion anywhere?
AND - what kind of meadow muffin dealies do you have sticking through that radiator? Looks like 4 stick'um through-ers there...are they holding something on the front?
Old Feb 11, 2013 | 02:27 PM
wilcam47's Avatar
wilcam47
prob an oil cooler of some sort maybe ac cooler
Old Feb 11, 2013 | 05:52 PM
thagoldenb's Avatar
thagoldenb
Originally Posted by SparkyRnD
if you overheat while driving, it can be vacuum advance, timing, lean carb or not enough air flow over the fins of the radiator.
what is vacuum advance? and is there any tests I can perform to see if there is something wrong with it and also lean carb? I can check the timing.
Old Feb 11, 2013 | 05:53 PM
thagoldenb's Avatar
thagoldenb
Not that I have noticed. I will check the level in the radiator.
Old Feb 11, 2013 | 05:57 PM
thagoldenb's Avatar
thagoldenb
Yeah the bottom of the radiator isn't the greatest. There are fins that are corroded and have broken off but not like crazy. top is fine! Could that be the problem? I was looking at radiators and they are like $200+ so I definitely don't want to just start throwing parts at it. Yes there is a transmission cooler held on in front of the radiator.
Old Feb 11, 2013 | 09:33 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Those part numbers I gave are for the thermostats that have the internal bypass blockoff. CHECK THIS! It is a cheap way to be sure. I have ran a lot of engines with no spring in the bottom hose and they ran fine. I don't think that this is necessarily your first place to look. If the coolant can't circulate (thermostat) no amount of fans will keep it cool. You can pull a plug or two and check the color. This will atleast tell if there is a lean condition or way too much timing. If they are white then correct that.
Old Feb 12, 2013 | 06:55 AM
thagoldenb's Avatar
thagoldenb
Thank you for the advice! I will check those two things today.
Old Feb 12, 2013 | 07:32 AM
MikePacey's Avatar
MikePacey
Take a air hose and blow it through all the fins to clean everything out. A good way to tell if you have something stuck in your cooling system is to remove the radiator cap and see if you an see the coolant circulating when its running.
Old Feb 12, 2013 | 09:41 AM
wilcam47's Avatar
wilcam47
I was thinking possibly timing as well...vacuum advance is on your distributer its the small round canister with a vacuum hose attached to it(you have a picture of it in the pic you took of the fan). Sometimes the spring will wear out advancing the timing too much.
You could try flushing your radiator...they have a bottle treatment at parts store you dump in the radiator and let it run for 20-30 minutes then empty the radiator...or get it professionally cleaned...they take it apart and clean it all.
Old Feb 12, 2013 | 11:27 AM
Filthy Beast
Agreed...but, if the timing was advanced too much, would there not be some detonation heard under load? Have you heard any of that dreaded 'pinging' when you punch it?
If you do flush it yourself, you might want to observe how much fluid comes out - you should have 4 gallons of fluid in your motor & radiator.
Then, I would flush the radiator first - by itself - add a little food coloring in a bucket of water just to see the flow, then flush again 'till clear. Then the motor - pull the thermostat and check it (mentioned above), then flush it.
BleackBeast
Sep 7, 2017 09:21 PM
1990inline6
Dec 16, 2013 12:32 AM
A2brb
Aug 27, 2009 02:52 PM
RhinoScores
1983 - 2012 Ranger & B-Series
16
Feb 10, 2008 03:33 PM
MickeyP
Jul 8, 2002 07:05 PM
