DATC heat issues
The “Dual Automatic Temperature Control” The passenger side has warm air while the driver’s side has cold air regardless of the temp setting.
Regardless of being in Single mode or Dual mode, is always blasting cold air on the drivers side and hot on the passengers.
Has their been a resolution for this issue ?
Is this a DATC Module replacement for fix?
Greatly appreciate the help!
Thanks
ESOF works fine and I think the vacumme does not control the heater on the DATC anyway (correct me if I am wrong).....
DTCB2266 (Left Side Blend Door Circuit Failure) — The module senses no change inactuator feedback voltage when the actuator motor has been energized.
Temperature control is inoperative/does not
operate correctly — DATCsystems,
vehicles equipped withelectric heater
POSSIBLECAUSES
• Circuitryopen/shorted
• HVACmodule — DATC
• Temperatureblend door is binding or stuck
• Temperatureblend door actuator
• GOto Pinpoint Test N.
Good news for me as it identifies that is one of 2 possible issues;
1 - stuck door
or
2 - faulty actuator
I suspect the later 2 as the failure because when touching the actuator in vehicle and cycling temp for driver side, I feel absolutely no attempt of movement from the actuator.
What I am trying to find out now is does the entire heat cabinet need to be removed (ie dash, and all) to get this out?
The actuator is visible, accessible to the harness connection, but the floor vent to the passenger side prevents getting at the screws to remove the actuator.
I have tugged and pried a little bit on the floor vent but no succes in removing it, and didn't want to force/break it until asking here, can and how is this floor vent/tube removed from the passenger side? I see no blts, no screws, no clips holding it in. Where it attaches to the main unit is simply a slipclip fit, but there seems to be something holding it on the right side.
Much appreciate any help in removing this... (without taking dash out...
