02 expy, super loud clunking
Old Jan 27, 2013 | 11:56 AM
s2gots's Avatar
s2gots
Hi guys, yesterday I picked up an 02 expy, with A4wd, and self leveling suspension. it has 130k miles. I got it for a good price because of the issue it has. Example- its parked on the street, turn the steering wheel to the left to pull away from the curb, rolls about 5 feet, and then theres this super loud clunk from under the vehicle that shakes the whole truck...feels like the trans is going to fall out, or it skipped/broke a gear tooth..after that it drives perfectly fine. transmission shifts normal and is super smooth shifting. Upshifts and downshifts without any problems on the city streets and highways. Theres no other vibrations, no funny noises, no funny smells..
Since yesterday, ive driven it about 50 miles on the highway, and it was perfect! Driven probably 15 miles in town, and it drives great also, except when pulling away from a curb, and/or backing out of my driveway. Now, It doesent happen all the time, I noticed if I ease on the throttle on take off, it wont happen as offten..
I did a bit of research on the site last night, and read about the GEM and pulling fuse 104. Im going to go do that now and test drive. Any insight would be great, hopefully its something I can fix my self, and not need to take it in to a mechanic...
TIA
Old Jan 27, 2013 | 12:44 PM
s2gots's Avatar
s2gots
I pulled out the fuse, but it still does it...any help you guys give me will be greatly appreciated!!
Old Jan 27, 2013 | 01:43 PM
alloro's Avatar
alloro
Sounds like the rear drive shaft is hanging. Here, try the fix in this TSB and see if the problem clears up.
04-1-6***NOISE - DRIVELINE CLUNKING/GRUNTING NOISE
Old Jan 29, 2013 | 06:57 PM
s2gots's Avatar
s2gots
It turns out its the transfer case that's bad. Took it to a reputable trans shop, they said $1400 to replace it with a remanufactured one... Does any one know if that's the normal going rate for this kinda job??
Southsideva
Nov 23, 2015 08:52 PM
Bob Landry
6.2L V8
13
Jun 17, 2013 05:28 PM
lrdmora
Nov 2, 2012 10:20 AM
expy37at
Jan 7, 2009 02:14 AM
hang10
Modular V10 (6.8l)
Jul 20, 2003 09:47 AM
