Help please
Old Jan 27, 2013 | 10:29 AM
Paul52097's Avatar
Paul52097
Help please
OK i have a 94 E350 5.8 . I cant seem to get the mpg up !
It also is popping in the intake when u accelerate hard .
I was wondering if not enough exhaust back pressure has anything to do with this ! It has true 2 1/2 duals with flowmaster mufflers . NO CAT'S !!
Would resonators help or no ?????
Also why would one side run warmer than the other ??
Is it ok to block off the crossover tube on the back of the heads ??? It rotted off so its blocked.
Would New o2 sensors from a 2000 - 2013 f150 cause any problems on my 94 E350 ????
I keep trying to work these issues out but every time it seems like im going backwards instead of forward .
Any hep is appreciated !!!!
Old Jan 27, 2013 | 10:47 PM
tabijan's Avatar
tabijan
I don't think lack of back pressure can cause low mpg.
Popping in the intake manifold? Are you sure it isn't knocking, pinging or valve float? Check ignition timing and advance.
EPA ratings say dropping from 5.8 to 4.9 is good for a couple of mpg so I wouldn't hold my breath that engine mods will make big improvements. Drive like a granny if mpg is that important to you.
Sixto
93 E150 Chateau 5.8 185K miles
Old Jan 27, 2013 | 10:50 PM
Paul52097's Avatar
Paul52097
Its only getting 5-7 mpg .....
Old Jan 28, 2013 | 12:19 AM
joshofalltrades's Avatar
joshofalltrades
your combination of popping in the intake plus different exhaust temps left vs right points to a problem in one or two cylinders. i would suggest doing a compression test or leakdown test to help you identify if you have a bad valve, leak between cylinders, or what.
as for your o2 sensor thoughts in the first post, it'll be happiest with what it was made to run with. will the others work? likely, but i wouldn't guarantee it. the computer knows what to expect from the sensors it was made to work with
5-7mpg isn't right. check to see if your timing is set correctly, AND to verify that it advances as you rev the engine. is the check engine light on? have you tried to pull codes?
Paul52097
Dec 29, 2012 10:20 AM
mike L
General Automotive Discussion
May 14, 2011 07:34 AM
cjben
20
Dec 4, 2009 06:23 AM
JJAPHIPPS22
1983 - 2012 Ranger & B-Series
15
Feb 25, 2008 08:34 PM
aero92
Aerostar
21
Jan 31, 2006 01:20 AM
