orings
Old Jan 27, 2013 | 01:27 AM
axel 56's Avatar
axel 56
orings
Need help with the getting the size of the orings that go on the plugs thatare in each end ofthe heads
Thanks
Old Jan 27, 2013 | 02:51 AM
richdawg's Avatar
richdawg
Here are some links to Riffraff Diesel Performance a sponsor for this forum, he has available most of the parts you will need for a PSD. The parts he carries are quality, it's very important that you use good parts for good results.
Riffraff Diesel Performance Parts: Diesel O-rings | 7.3L Powerstroke O-rings | Diesel Injector O-rings | Replacement O-rings - O-rings
Riffraff Diesel: Oil Rail End Plugs - Cylinder Heads
Quantity in Basket: None
Code: GZ-15-007
Price: $7.49
Old Jan 27, 2013 | 05:11 AM
427 fordman's Avatar
427 fordman
Buy the plugs too. Only a couple bucks more. I just put new ones in the rear since it was accessible now.
Old Jan 27, 2013 | 08:46 AM
axel 56's Avatar
axel 56
I am going to try to stop leak today so if I can get it out I will probly just replace oring unless Lordco or Baker has the plugs as they are the only guys open here on sunday .
Old Jan 27, 2013 | 09:33 AM
fordpride's Avatar
fordpride
Click on the blue link
Powerstroke O-Ring Chart
Old Jan 27, 2013 | 12:26 PM
fordman67's Avatar
fordman67
Stop leak? Haha its 3000psi....good luck with that
Old Jan 28, 2013 | 09:13 AM
axel 56's Avatar
axel 56
Going to see if dealer has the plugs today I was not aware that there was that much presure there .I did not take it out yet . Good thing I did not mess with it or I would be walking
Old Jan 28, 2013 | 10:53 AM
91 Dually's Avatar
91 Dually
I tried.buying the o-rings ftm dealer with mo luck. They only well the new plugs with o-rings on them. Also, check installation instructions. Supposed to put a certain type thread lock on those.
Old Jan 29, 2013 | 01:57 PM
axel 56's Avatar
axel 56
Got plugs and orings yesterday I could not get the plug out with the tools I had even tried makeing a pices to go in a flex bar but the angle was to much I was woried I mighg crack the oil galley so I took to dealer . ?
Old Jan 29, 2013 | 02:54 PM
427 fordman
A hole in the firewall has been drilled before by people to access those plugs. How much did the dealer quote you to do the repair? I don't know what their procedure to change them is.
Old Jan 29, 2013 | 08:39 PM
axel 56's Avatar
axel 56
They changed the one under the down pipe and the one under the ac cost was 257.00
Old Jan 29, 2013 | 08:43 PM
427 fordman
Could have been worse. Basically all labor, but at least you got it fixed.
Old Jan 29, 2013 | 09:28 PM
axel 56's Avatar
axel 56
Yep and they did the hard ones .but now it turns over alot before it starts . It did this at the dealer and I asked because its always flashed right up they said it would clear up after I drove it awhile but after I did thjs and parked it for afew hours it was
The same turned over alot
Old Jan 30, 2013 | 06:14 AM
427 fordman
It's got air in the system. It will do that for up to 200 miles. Take it and run it pretty hard and it will clear up faster.
Old Jan 30, 2013 | 12:16 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Does this chart works for a OBS or only for SDs?
