Sponsored by: Kumho
ebrake adjustment?
Old Jan 26, 2013 | 09:55 PM
mudrat025's Avatar
mudrat025
ebrake adjustment?
i have a 1997 ford f250 heavy duty with the 7.3 diesel. i went to adjust the ebrake the other day and found no adjustment point. every vehicle i have ever owned had a adjustment point but no where on this one?i am thinking of cutting the cable under the rig make 2 loops with cable ferrules on each ends of the cut and put one of those tighteners you would put on a barb wire fence just smaller... any thoughts.
Old Jan 27, 2013 | 09:48 AM
fmtrvt's Avatar
fmtrvt
It's a balanced tension system. The take up reel at the apply mechanism has a tension reel while there is a opposing compression spring at the end of the parking brake cable where it attaches to the paring brake lever inside the drum.
If you have a low pedal it is usually an issue with the drum brake shoe adjustment unless thee is a failure of the take up reel or cables.
tsevrens
31
Feb 7, 2023 10:14 AM
cub102
Jun 11, 2015 10:01 PM
Carmen10
1997 - 2003 F150
Dec 30, 2008 06:40 PM
supersonicss
Feb 13, 2006 12:36 AM
