My 272 usually starts fine hot or cold. But it does seem to catch a little quicker when it is cold. I don't know the amps on my 6-volt battery but it is what they list as a "Group 2." I used to run a group 3, but it seemed a little small and weak. Good luck, John
Flatheads are notorious for vapor lock when hot as well as an old coil acting up. Coils break down normally with age and heat is a major problem. I remounted mine well above the usual head location allowing air circulation under it. (On a 53 Vicky).
Vapor lock can sometimes be cured by using a double action fuel pump as well as locating all fuel lines well away from heat. An electric pump is another "cure" but this requires a pump and regulator set for 1.5-2 lbs max pressure.
As far as 6V is concerned it is imperative that the starting system be as new or better. This means new 0 or 00 gauge cables, perfect grounds as well as shortening up the battery ground path when possible. Many reroute the ground path and now go from from the battery to under a starter bolt and then to a shiny frame location. When I redid my 54 F350 it made a world of difference.
You may want to check your starter also because if the brushes get to hot it will make the starter drag until the engine cools down then it will turn over fine again.
Originally posted by johntownsel My 272 usually starts fine hot or cold. But it does seem to catch a little quicker when it is cold. I don't know the amps on my 6-volt battery but it is what they list as a "Group 2." I used to run a group 3, but it seemed a little small and weak. Good luck, John
Hey John, I was just looking at some battery stuff to check on what would have been stock in my 56. Here's a web site that explains the group ratings, cold cranking amps, hot cranking amps, etc. Enjoy.
