flywheel trouble
Old Jan 24, 2013 | 08:17 PM
cameroncorey95's Avatar
cameroncorey95
flywheel trouble
Hi I'm going through a phase with my 79 Ford f150 469 where I AK burning through starters . I think I'm going to switch out my flywheel . Right now it has a 164 tooth flywheel can anyone tell ne what kind I am suppose to have need to get rid of this grinding asap
Old Jan 24, 2013 | 08:56 PM
351coupe's Avatar
351coupe
The 460 swaps eat starters if not done right.
If you have an internally balanced 460(78-earlier),they probably used a 360/390 flywheel..but still have the 460 starter.It wont mesh right.
If thats the case...I believe the cheapest/easiest fix is a 351m/400 starter with the drive from a 360/390 starter.
Old Jan 24, 2013 | 09:38 PM
cameroncorey95
How do I get a 351/400 starter with the drive of 360\390 starter ?
Old Jan 24, 2013 | 09:43 PM
cameroncorey95
Old Jan 24, 2013 | 09:44 PM
cameroncorey95
And will it still engage properly ?
Old Jan 24, 2013 | 09:47 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
You might have to disassemble the 2 starters and swap the drives out or gear, what ever it requires, I always converted autos.
Old Jan 24, 2013 | 09:52 PM
cameroncorey95
So I have to but two starters to fix the problem? Wouldn't it be easier to just swap the flywheel
Old Jan 24, 2013 | 10:01 PM
cameroncorey95
Or could I just find a starter like that? Or would I just have a mechanic do it
NP435Bronco
15
Dec 1, 2025 09:45 AM
Ford59galaxie
Mar 28, 2012 08:08 PM
wizzard351
Apr 19, 2009 11:02 PM
FordDude88
Oct 7, 2006 12:25 AM
Thomsen
Mar 1, 2004 12:24 PM
