HELP! Coolant leaking 4.6
Old May 28, 2003 | 04:53 PM
jack'd up's Avatar
jack'd up
Angry HELP! Coolant leaking 4.6
I am working on a 1997 F-150 with a 4.6. It ran fine till yesterday. It started to leak coolant from the back of the motor were the auto bell housing and motor meet. I thought it was a bad freeze plug so I pulled the trans. But the freeze plugs were fine. It is coming from a hole the size of a freeze plug just above the rear main seal cover plate. It has a plastic cover in it shaped like a freeze plug (I guess a dust or inspection cover) I know that water is not supose to be there or it is an overflow. What would be causing this. I can pour water into the tank and it just pours out the back of the block. Thanks in advance.
Old May 28, 2003 | 10:16 PM
jack'd up's Avatar
jack'd up
TTT Anyone?
Old May 28, 2003 | 10:32 PM
Ultramagdan's Avatar
Ultramagdan
I've tried to access my database and cannot find a reference to your plastic cap. I assume there are no wires going to this?
Old May 29, 2003 | 07:37 AM
jack'd up's Avatar
jack'd up
No wires going to it. I would just put in a rubber plug but if it is some kind of over flow and something else is wrong I don't want to ruin the engine. It is more like a plastic plug or inspection cover
Old May 29, 2003 | 04:41 PM
Ultramagdan
The only thing I come up is that the service manual mentioned cracks that can appear in the back of the block. These are repaired with a Ford approved Epoxy if the cracks are minor in nature. If you have a larger hole/crack that could be why it's leaking.
