Sponsored by: Kumho
add-a-leaf question?
Old May 28, 2003 | 04:21 PM
fordboy1973's Avatar
fordboy1973
I was wondering if you could stack 2 add-a-leafs per spring to lift it a little more than with just one or will that not work?
Old May 28, 2003 | 04:45 PM
RRMike's Avatar
RRMike
I'm sure it would lift it some more but probably not as much as the first spring. For instance if 1 spring did 2" then another might do 1 or 1-1/2 more. The thickness of the spring alone will lift it some
Old May 28, 2003 | 10:17 PM
fordboy1973
I might try it it depends on how much each add-a-leaf costs
Old May 29, 2003 | 12:38 AM
MustangGT221's Avatar
MustangGT221
That would be 1 heck of a stiff ride.
Old May 29, 2003 | 03:43 PM
fordboy1973
do u think it will really be that stiff of a ride? I will be using it for mostly off road use but it will see alittle on road use.
Old May 29, 2003 | 08:48 PM
wille3r's Avatar
wille3r
Trust me , one set is stiff. Two sets and you`ll loose your teeth and bruise your kidneys. Try it though and let us know how it works!!
