I have 1973 f250 Highboy with a 4 inch body lift along with the 4 inch stock suspension lift i want to lift it even further to fit bigger tires i am looking at about a 4 inch lift. What is the cheapest and most effective way to do it, remember i am on a budget?
So your total lift is a 4" body lift? The highboys sit about 4" over a 77 1/2-79 F2504x4. Skyjacker and Superlift both make 4" suspension lifts for your rig, you should fit 44s no problem, maybe with cutouts.
Basically your 4" over factory heigth. I hate to break it to you but there is no cheap way to lift a highboy. 4" lifts run in the $500+ range and that's w/o new rear springs.
How big of a tire are you wanting to run? I basically have a total of 4" of lift on my highboy and w/ the cut fenders 38's fit easy. Check out my gallery for some pics. W/ a 4" suspension and 4" body lift anything less than 40's would look rediculious. If your on a budget 40's may not a great idea.
