vibration damper puller
Old Jan 22, 2013 | 05:23 PM
Dholtham's Avatar
Dholtham
Hey guys.. im removing my front cover off of my 97 7.3 because its leaking oil very bad.. Just wondering where i could find a cheaper vibration damper puller/installer? Stores or websites? I was gonna rent one at my local autozone but they told me they do not carry one.
Old Jan 22, 2013 | 11:06 PM
oldbird1965's Avatar
oldbird1965
Can't help but this will give you a bump to the top.
Old Jan 23, 2013 | 05:29 AM
91 Dually's Avatar
91 Dually
It doesn't take a special puller. I used the one I got from Harbour Freight a while back. The combination steering wheel/damper puller. You are aware the oil pan has to come off before pulling the front timing cover? and the engine needs to be pulled before the oil pan can be removed?
Old Jan 23, 2013 | 01:05 PM
fordman67's Avatar
fordman67
what dually said..normal bolt grip puller pulls it right off.I just pulled my core engine apart last week and it is no big deal to pull balancer.
I just hope you have the engine out first...
Old Jan 23, 2013 | 04:39 PM
Diesel_Brad's Avatar
Diesel_Brad
Advance Auto has one that you can rent
Old Jan 26, 2013 | 05:59 PM
Dholtham's Avatar
Dholtham
yeah i have my engine on a stand. I got the damper off and pulled the front cover.. I see a couple of gaskets i need to replace.. Where exactly do i need to put RTV on the cover?
Old Jan 27, 2013 | 08:12 AM
Diesel_Brad
I am trying to think back to a PSD. I dont think you need any RTV on a timing cover
Old Jan 27, 2013 | 08:18 AM
mueckster's Avatar
mueckster
IIRC, some of the early HPOP reservoirs needed a bead of RTV to seal to the top of the timing cover. The o-ring type gasket only went around the oil delivery passage.
Old Jan 27, 2013 | 10:40 AM
Dholtham's Avatar
Dholtham
So i dont need RTV on the inside of the front cover? There are two o-ring gaskets on each side of the cover for coolant i think.. they look pretty bad but on the passenger side of the engine is where the oil was coming out of the cover.
Old Jan 27, 2013 | 11:21 AM
fordman67's Avatar
fordman67
Rtv goes 3 places on tc. Top across.sides from oring to pan rail.hpop resivour nada!i can throw pic of tc up if you need pic.
Old Jan 27, 2013 | 11:22 AM
91 Dually's Avatar
91 Dually
Check out this manual... 1996 Bronco/F-Series Workshop Manual
Go to "ENGINE... "7.3.... "FRONT COVER.... <<Says to use silicone on the gaskets>>
Old Jan 27, 2013 | 05:04 PM
Dholtham's Avatar
Dholtham
wow thats a great manual.. Thanks.
Old Jan 27, 2013 | 07:36 PM
mueckster's Avatar
mueckster
Taken from the manual in 91 Dually's link. Sealant is shown to be used (on a '96) to seal the timing cover to hpop reservoir.
Name:  '96 7.3 hpop reservoir.gif
Old Jan 27, 2013 | 07:47 PM
fordman67's Avatar
fordman67
Huh...i just had mine off.it had o,ring type gasket.no rtv needed
Old Jan 27, 2013 | 07:50 PM
Dholtham's Avatar
Dholtham
Mine also has an oring gasket on it. On the timing cover though.. do i put a bead all the way around the outside cover including the oring gaskets or just underneath them and across the top of the cover?
