Rear AC install??
Old May 28, 2003 | 01:29 PM
Crapgame's Avatar
Crapgame
Rear AC install??
I have a 97 EB Expedition and was wondering about putting in rear air. My center console has vents in the back above the audio controls so is that sufficient? If not would installing the rear air be a lot of work? I know I would have to change out the headliner, center console etc but what about the electrical side of it?? Oh one other thing. I have the power roof also. I Probly have enough sources of cold air right?? Thanks
Old May 28, 2003 | 01:59 PM
buzzard's Avatar
buzzard
Rear AC install??
I'd bet you're looking at a fairly hefty $$$$ figure to do it right. You'd have to run the lines back to the rear quarter panel cubby hole. Then you'd have to install a evaporator coil and/or whatever else is back there. Then you would have wiring issues, ducting issues, etc. I'm not saying it can't be done, but it will cost you.
