My check engine light comes on once the truck has reached its operating temp. But the catch is it only happens when im driving around town and not on the highway. I just recently installed a 180 degree thermo to replace my defective 195 and the engine light started comming on a few days after I replaced it. The codes I pulled from the ECM are: KOEO=11 system ok, 41 (Oxygen sensor signal fault, switching not detected) that was in the continuous memory
KOER= 41 System running lean, 52 Power steering pressure switch open
A couple things I could think of would be a bad oxygen sensor or fuel pressure regulator. Anyone have a plan of attack before I spend money on something I dont need? Thanks
I could be wrong, but I thought I read the lowest you could go with our computerized trucks was a 190 degree thermostat.
If you only changed it to cool the engine better during hard use, I'd suggest using a 50/50 mix of water to antifreeze (the lower the anti-freeze, the better it cools - but then you do need some in there to lubricate the water pump seals), and add a bottle of Redline Water Wetter instead (meaning you probably need put the right thermostat back in and reach your end-goal by a different means).
Maybe an aftermarket 'performance chip' could lower the expected temp. range of the computer... but they aren't supposed to do much for I-6's otherwise, so it probably isn't worht the money.
If you're getting a code for the HEGO, I'd replace that first - unless you've recently done it. They're essentially maintenance items anyway and should be replaced on a regualar basis. You can get Bosch brand sensors at Autozone for around $41.
Then disconnect the batt for 10 minutes or so, drive it again and see what codes still appear.
Thanks guys, I replaced the 195 with a 180 just because I heard it was good to. Now my temp reads between the N and the cool mark. MOre towards the n. I replace the O2 and see what happens.
You probably should go back to the 190° thermostat. At 180° the engine coolent may not get hot enough to get the fuel flow down to run from rich start. Particularly if you live north of I-10. I tried that once for about 1 week. Every time the outside air temperature was below about 70°f and the thermostat opened the coolent temperature would drop below the run sensor temperature and the computer would change back to a richer mixture for the injectors. The engine would run rough and the mpg would get lower. Turns out that the engine will run fine at 195° and as long as the coolent is maintained and the system is working. I have run my truck for hours with the coolent temperature at about 230° and all is still well at 160,000 miles.
