oil pressure/gauge problem ?
Old Jan 19, 2013 | 01:17 PM
jeffbradbury7's Avatar
jeffbradbury7
Can I put a Y pipe under the oil pressure sending unit and attach a real gauge to it under the hood, and still have the dash gauge functional ?
Old Jan 19, 2013 | 04:49 PM
tecgod13's Avatar
tecgod13
Yes....
Try the search function for a whole bunch of threads showing how others have done it.
Old Jan 20, 2013 | 10:03 PM
dyoungen's Avatar
dyoungen
I added the "T" so I could see the REAL oil pressure. When I first got the truck the needle was on the "N" but after she warmed up would drop almost to the low pressure line. I wasn't to worried after reading posts about the oem gage problems. I did want the gage to work so I could see how the two compared and after doing the "T" I see no problems. At cold idle the pressure is 50 lbs idleing and after warmed up idleing it's between 15 and 20 lbs. Running at highway speeds will get me 40 to 45 lbs. The way I was told, these engines rely on oil flow and not oil pressure.
nathan66669
Nov 19, 2013 01:27 PM
tony b
Nov 6, 2006 12:31 AM
bpsenette
1997 - 2003 F150
Nov 2, 2006 03:04 PM
cscottyr
1983 - 2012 Ranger & B-Series
Sep 16, 2004 08:28 PM
oldgoat49
3.0L V6
Dec 8, 2003 10:34 AM
