po720 code
Old Jan 18, 2013 | 05:04 PM
dsorrell06's Avatar
dsorrell06
po720 code
Hello fellow readers,
I'm a independent mobile mechanic in the greater los angelos area and I was called out to replace the output shaft speed sensor on a 01 naviagtor 5.4 L 2wd. First thing I did was pull the code cause check engine light was on. It read me Po720, which is, output shaft sensor malfunction. Odometer wasn't working either. So I replaced it. I then cleared code and drove it. Light never came back on but still no odometer function and it threw a pending Po720. Any thoughts?!
Old Jan 19, 2013 | 06:45 AM
projectSHO89's Avatar
projectSHO89
Did you follow the pinpoint diagnostics in the service manual or did you just hang a part on the truck?
Old Jan 19, 2013 | 10:46 AM
alloro's Avatar
alloro
Does the speedometer work?
bigbugman
Jun 30, 2023 04:45 PM
bilbrey
2004 - 2008 F150
Dec 5, 2011 07:21 PM
2001 5.4 Supercrew
1997 - 2003 F150
Dec 8, 2010 11:09 PM
fseries01
1997 - 2003 F150
Jan 2, 2009 07:31 PM
