Humming
Old Jan 18, 2013 | 03:16 PM
Big Green Bus's Avatar
Big Green Bus
Humming
I'm sure this is beat to death but... road hum driving at all speeds same pitch when slipped into N, sounds like the old mud grip tires or boggers. oil levels fine in pumpkins, 199,000 miles on 2003 6.0 Diesel X limited 4x4 other than this the truck is perfect and no issues....well the dvd player doesnt work....am I looking at wheel bearings? inner/outers in rear, sound is all over cant tell if its front or rear should all bearings be replaced at same time front and rear?, no vibration from 0- 105 mph( got to test its limits ) going to advance auto in A.M.
Old Jan 18, 2013 | 08:53 PM
jh818's Avatar
jh818
Maybe you have a Hummer stuck underneath...
Has it always been like that since you put those tires on?
Old Jan 18, 2013 | 10:39 PM
tims01's Avatar
tims01
check your windshield gasket at the roof where the top of the front window meets the roof... mine did the same thing for months then one day i boosted up to 9mph and pop fapfapfap pull over look everywhere .. finialy found out the seal became loose
Old Jan 19, 2013 | 12:22 AM
5.4T's Avatar
5.4T
I think its the dvd player.....
Old Jan 19, 2013 | 11:31 AM
Big Green Bus
Originally Posted by jh818;[URL="tel:12730922"
12730922[/URL]]Maybe you have a Hummer stuck underneath...
The noise started about 1k miles ago... no hummers underneath...not yet anyways....
pulled front hub off this morning,every thing looks ok cant tell if its bad or not, the little needle bearings look new, looking in the antilock sensor hole dont see anything, grease looks dark but I dont know if its bad or not lock hub turns smooth...maybe just shoot it full of grease and see what happens
Michael Cloninger
Aug 17, 2019 10:38 PM
IHateCommieCars
Jun 14, 2018 11:27 PM
dakotajeep
Jan 19, 2013 09:17 AM
Daewoo
Feb 1, 2012 01:00 PM
colour
Jul 22, 2004 06:55 PM
