Blue Spring FPR
Old Jan 17, 2013 | 10:59 PM
cbr600rx7's Avatar
cbr600rx7
Blue Spring FPR
Does anyone know what the FORD part number is for the blueFPR spring? I have searched and tried calling with 3 different part numbers. IHwasn’t able to cross reference the numbers I had and after sitting on hold withford for 10 minutes still no luck.
Old Jan 17, 2013 | 11:17 PM
glovemeister's Avatar
glovemeister
I believe you are looking at a 6.0 mod, unless you are talking about the Cali spring which increases the fuel PSI on 7.3's.
Old Jan 18, 2013 | 08:26 AM
cbr600rx7's Avatar
cbr600rx7
The fuel pressure spring on my grandfathers truck is bent and is causing the truck to hesitate and die.
Old Jan 18, 2013 | 08:37 AM
Talyn's Avatar
Talyn
Ahhh, somebody pulled it and didn't re-install correctly.
One of the members might be gracious enough to send you one.
But you'd have to get an FPR rebuild kit I'd think. (not sure on that)
Old Jan 18, 2013 | 09:24 AM
cbr600rx7's Avatar
cbr600rx7
Yeah thats the number i keep trying to find. But i cant track down the right part number.
Old Jan 18, 2013 | 09:28 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Maybe this helps you:
Fuel Pressure Regulator Spring
(International) 1823643C1 (federal emissions; 94-98)
(International) 1825854C1 (CA emissions; engine serial no. 201681-98)
Fuel Pressure Regulator (contains spring, valve spool & new brass plug)
(Ford) F5TZ-9K061-A (federal emissions; 94-98)
(Ford) F6TZ-9K061-AA (CA emissions; engine serial no. 201681-98)
Old Jan 18, 2013 | 07:59 PM
cbr600rx7's Avatar
cbr600rx7
What is the best way to go here. Is it better to just get the spring from International or the hole kit from ford. Also correct me if i am wrong but does the CA spring provide a little more pressure.
Fingers 351
Sep 10, 2015 12:04 AM
ToMang07
Maine Chapter
121
Apr 1, 2015 09:42 AM
smallello
Arizona Chapter
Feb 29, 2012 08:45 AM
KTM Mike
Mar 2, 2007 11:52 PM
