Slight pull on idle... fluctuating
Old Jan 17, 2013 | 01:09 AM
Ianmattf100's Avatar
Ianmattf100
1963 223 3 on tree. Been running great however have noticed as of late there is a slight dip in idle every 2 - 3 seconds. Something is pulling on it. I though maybe a points to pertronix conversion would fix it. Added pertronix coil and ignition but its still doing it. The autolite carb was rebuilt by a pro 2 months ago. Had a radiator issue and truck got to about 210 on highway. I kind of noticed the fluctuation in idle just after this. I also had just recently added some stuff to radiator to stop heater core leak. Where should I start on testing? Could I have fouled a plug? Thanks guys
Old Jan 17, 2013 | 09:13 AM
bertha66's Avatar
bertha66
Originally Posted by Ianmattf100
1963 223 3 on tree. Could I have fouled a plug? Thanks guys
Yes, that is a good place to start and check out the plug wires also.
Old Jan 17, 2013 | 07:23 PM
Redmanbob's Avatar
Redmanbob
With what: Fuel Pump and Vacuum Tester
How to: How to Use and Interpret a Vacuum Gauge
Old Jan 18, 2013 | 10:01 AM
huckdeuceman's Avatar
huckdeuceman
I would also check the ''air/fuel mixture on the carb!, even tho it is rebuilt it could need some fine tuning?
Old Jan 18, 2013 | 12:20 PM
rogue40's Avatar
rogue40
Do you have a amp meter and if so does it fluctuated when the idle dips?
areoseek
Mar 23, 2013 11:28 AM
erawtik
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 29, 2004 09:17 PM
wezol5484
Aug 23, 2004 09:02 AM
fordman777
Sep 26, 2003 07:02 PM
77monster
Aug 1, 2003 10:32 PM
