M112 Supercharged 4.2 V6
Old Jan 16, 2013 | 08:51 PM
2001_4.2's Avatar
2001_4.2
Just wanted to share my build I just finished up. It was a blast building this up and I'll be the first to admit it still isn't the fast truck on here but it's definitely a unique one! Share your thoughts, comments, and questions!
Thanks guys!
Test fitting
Building my manifold
Idler pulley bracket
Under drive pulley
Fuel Injectors
Old Jan 23, 2013 | 11:57 AM
Beechkid's Avatar
Beechkid
my absolute compliments to you!!!!! it reminds me of "stuff" I and my family have done- It is soooo good to see someone use their knowledge, skills & abilities to create what they want and make it happen successfully (as compared to- look at me, I bought all this stuff, paid someone else to install it- and it's better than yours!)
It's very clear the work that you did in not just doing but the planning involved...very, very impressive.........
Ok- all you guys & gals out there- pay very close attention to this guy....this is a real car/truck (tim Allen grunt, grunt) GUY and how its really suppose to be done!
Old Jan 25, 2013 | 12:35 AM
2001_4.2's Avatar
2001_4.2
hahaha I love it man! Thanks a bunch! So many guys out there say "oh that's a V6? Pssshhh
So now this makes me love this thing even more!
Old Mar 20, 2013 | 05:32 AM
UNTAMND's Avatar
UNTAMND
Awesome job.
I've been reading and replying to a lot of topics here in the performance/boost section to get my inspiration back. I've been out of the loop a few years and this is giving me great motivation.
Keep up the good work.
Are you using 6 or 8 rib serpentine belt. I need to find a lower 8 rib pulley and was curious what you used. I'm tempted to try a supercoupe lower but parts are hard to find. I've thought about just using a 6rib but wasn't sure where my hp goal was.
Old May 22, 2013 | 10:08 PM
2001_4.2's Avatar
2001_4.2
Originally Posted by UNTAMND
Awesome job.
Thanks man!
Sorry for the late reply, I don't check this forum that much.
And it's just the stock 6 rib pulley system
Old May 23, 2013 | 07:35 AM
UNTAMND's Avatar
UNTAMND
How much boost are you getting.
Seems like the smaller underdrive crank pulley is going to limit boost. Was that your intention. The stock crank pulley being bigger should spin the blower faster for more boost, but also more heat. Water injection before the blower is your friend. And if you use straight water, no real tuning is needed. It will seal the blower better and it alone will usually make a little more boost.
How did you lign up the blower pulley with the accessory pulleys. Did you just eyeball it and close enough. I put an m90 on a corrado and that's all I did, and used a straight edge to get it close. Worked fine but just wanted a better way.
I was going to use the back portion of the blower pulley, just in case I did upgrade to 8rib pulleys later. I'm going to be doing this on a v8 so I may need the extra belt later on. Just trying to plan ahead.
Thanks for the info.
privateer, eh
1947 and Older Ford Trucks
Mar 9, 2016 09:27 AM
TuckinLikeAMuc
Kentucky Chapter
May 21, 2012 11:04 AM
andym
General Automotive Discussion
Feb 4, 2012 04:31 PM
jr32560
Maryland Chapter
171
Mar 8, 2010 09:04 PM
