Clutch
Old May 27, 2003 | 11:00 PM
SPF1969's Avatar
SPF1969
Clutch
I am having some major issues with my clutch, I have been working on it for 46 days.
The throw out bearing is squeeling, the clutch pedal feels mushy sometimes.
Here is a total recap of what's done:
1. New Pilot Bearing
2. New Clutch Disk
3. New Pressure Plate
4. New Throw Out Bearing
5. New Fork
6. New Input Shaft Bearing
7. Rebuilt T-Case
8. New Slave Cylinder
9. Bleed System As TSB States
10. Sucked Tranny Into Bell Housing
11. Wrapped Ratchet Strap Around Bell Housing / 1" crack on the edge.
12. Cried
13. Swore
14. Threw Tools
15. Worked On The Piece Of **** Straight For 46 Days
So is it possible to have a bad master cylinder? I got theTSB for bleeding the cylinders and I bought the bleeding tool also. I have a Elephant gun chambered at 300 Win Mag, and let me tell you I thought about it, 46 days, 46 dang days. Thanks for the help.
Old May 27, 2003 | 11:32 PM
steve83's Avatar
steve83
Clutch
You gonna tell us what vehicle/engine/transmission you're working on, or should we just use the Force? Are you reading a Haynes manual?
Old May 28, 2003 | 06:27 AM
SPF1969's Avatar
SPF1969
Clutch
Ok, so I didn't use the brain when I posted. It is a Inline 6 (4.9L) with a Borg Warner T-18 4 speed tranny and it's 4 wheel drive. I have read the Chilton's manual, skimmed the Haynes, and purchased the TSB's for the truck.
1993 F150
4.9L
T-18 4 Speed
4x4
Thanks,
Steve
Old May 28, 2003 | 08:10 AM
steve83's Avatar
steve83
Clutch
Wow! Who put a T-18 in a '93? What's the TRANS code from the door sticker? Are you using the original slave cylinder, an old external one, or some aftermarket parts? Where did the bellhousing come from?
Old May 28, 2003 | 08:14 AM
SPF1969's Avatar
SPF1969
Clutch
Steve83,
I am not sure who put anything in the truck. I was the second owner and I am not even sure it's the original motor. As far as the Bell Housing, it was in there when I got the truck.
The slave is brand new from the dealer and the master is a couple of years old and from a chain parts store.
Steve
Old May 28, 2003 | 08:31 AM
steve83's Avatar
steve83
Clutch
There are 2 styles of hydraulic clutch, and you have to match the master to the slave. I don't know when the dividing line is, but if you cross it, the clutch won't work. You might contact the webmaster at http://www.broncodata.com/ - he just changed from an E4OD to an M5OD and discovered that the hard way. He's more active on http://tellico.off-road.com/ubbthrea...fordbroncolate and his username is "havack". But reread the Haynes instructions for bleeding - he also had a lot of trouble until he followed those instructions, and now he loves the manual trans.
