getting ready for a trip
Old Jan 16, 2013 | 06:52 AM
kegomatix's Avatar
kegomatix
Pretty soon I'll be driving my 93 f250 5.8 4x4 about 3000 miles straight through. This month it's getting new tires, an alignment, wheel bearings front and back, new front rotors and brake pads, changing the transmission filter and fluid, oil change, differential fluid, and transfer case fluid. In the last couple months its gotten new spark plugs, plug wires, cap and rotor, starter, and power steering pump.
Any tips or heads up on things to look for or do before a trip this far? This will be the first time I've driven anything this old so far. The truck has 232,000 miles on it but is in good shape overall.
Old Jan 16, 2013 | 07:45 AM
Puddy's Avatar
Puddy
Well, I can tell ya I made the move out west and blew the tranny on the Sarnia, port Huron bridge. It sat for 5-6 year previous. Did oil changes etc. and the pump failed.
Really just make sure you have a credit card and enough to buy new parts.
Ensure all fluids are good, and everything is greased.
Old Jan 16, 2013 | 09:02 AM
kegomatix's Avatar
kegomatix
That's what I'm worried about. I should have enough backup cash for any emergency save for a blown engine or transmission (knock on wood).
Old Jan 16, 2013 | 10:44 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Off the top of my head, here's the spares I carry...
TFI (make sure you have the proper tool to replace it)
Distributor
PCM
Ignition coil
Ignition relay/solenoid
EEC Relay
Fuel pump relay
TPS
Alternator (or perhaps just the voltage regulator)
A failure of any of the above can leave you stranded and all are easily swapped road-side. Known-good used parts are fine as backups - that's what mine are for all of the above.
Old Jan 16, 2013 | 08:27 PM
ChefJeff1's Avatar
ChefJeff1
I would also check the belt and all hoses. Easier to replace at home then on the road.
Old Jan 17, 2013 | 03:17 AM
kegomatix's Avatar
kegomatix
DPDISXR4Ti, thanks. For whatever reason it hadn't occurred to me that I should stock up on spare parts... I will be carrying almost all my tools on me so I will be well equipped for whatever happens.
ChefJeff1, I forgot in my list that I had replaced the serpentine belt. I Need to go around and have a look at all the hoses, though.
Old Jan 17, 2013 | 08:03 AM
jroehl's Avatar
jroehl
When was the last time your transmission fluid was changed? If it's been quite a while, I wouldn't bother if it looks and smells fine. The reason is that if it's been a long time (several years, and more than 50,000 miles or so), there are deposit build-ups in the tranny on the seals and valves. New fluid will re-dissolve some of those deposits, and cause the transmission to either function poorly or not at all because the deposits on moving parts like valves were acting in part as seals.
Jason
Old Jan 17, 2013 | 09:03 AM
kegomatix's Avatar
kegomatix
It hasn't been changed since I've owned it, which has been about 6 months. I'm not sure when the previous owner changed it so I think it's safest to assume that it hasn't been done in a long time.
gliderguy
Jun 16, 2018 04:36 PM
Jonnylightning
Jun 8, 2017 07:32 PM
BEAL73
1983 - 2012 Ranger & B-Series
Mar 29, 2006 09:50 PM
BRX98GT
Sep 10, 2004 08:38 PM
Critterhunter
Jun 21, 2004 09:29 PM
