Temp guage fluctation
Old Jul 26, 2002 | 02:11 PM
Pastmaster's Avatar
Pastmaster
I recently flushed the antifreeze/coolant and got a new 13lbs radiator cap. I installed Zerex with a 75/25(est) mixture. Since then I have gotten a fluxuation from the guage. I used to get right at the O when at operating temp. Now it fluxuation from that point to cold constantly. And this is 95-105 degrees outside with the air conditioning on.
Normal?
'93 F-150 loaded and modified!
Check my Gallery
Old Jul 26, 2002 | 03:04 PM
gasman6674's Avatar
gasman6674
Stuck thermostat? (maybe)
Bad sender? (weird)
My 2cents
regards
Gasman
Old Jul 26, 2002 | 03:06 PM
brown 4x4's Avatar
brown 4x4
Mine has small fluctuations between the N and the R, as do others I have driven.
I am going to change/flush my coolant sometime too. Did you drain the block also? I haven't found a hole yet to do this.
[font color="green"]1995 F-150 Supercab XLT 4x4 302 M5OD 8' bed [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old Jul 26, 2002 | 03:18 PM
winfordr's Avatar
winfordr
Sometimes rapid fluctuation is caused by air trapped in the system. If there is no coolant on the sending unit, it will read cool.
I usually install a thermostat with a small hole in the top, or drill one there if it doesn't have one.
Other causes include
loose wire on the sending unit (maybe bumped during the flush).
Sticking thermostat - as mentioned above, although you would probably get hotter than normal if that is the case.
Winford
Old Jul 28, 2002 | 03:55 PM
Pastmaster's Avatar
Pastmaster
Well what's interesting is that it didn't do this until I replaced the cap. I know the thermostat is okay, as I replaced it about 25k. There is a drain on the both sides of the block, however the only one you can get to without actually removing the starter is on the driver side. I'm not sure what size of bolt it is, but I flushed the system completely.
Is the mixture to rich?
Check my Gallery
Old Aug 17, 2002 | 06:14 PM
gamehunter's Avatar
gamehunter
I recently had a problem with mine were the temp would go all the way up to the "R" or even the "M" and then back down to "N" were it has always been no matter if its -30 or 100 above with air on. I replaced the thermostat and it runs great now. I had to drain most of the coolant so that could have helped too. But I went to a 180 degree because I heard it increases the life of your engine and now it reads a little below "N".
Old Aug 17, 2002 | 07:01 PM
ckb2steelers's Avatar
ckb2steelers
dn29626
Jan 4, 2013 06:42 PM
schonauer
Dec 25, 2012 11:40 AM
shuttlevalve
May 30, 2010 02:22 PM
H2oSprayer
Apr 20, 2009 09:42 AM
1993F150302
Mar 12, 2005 11:53 AM
