HELP PLEASE!!!!!!!
Old Jan 14, 2013 | 07:52 PM
a79fordman's Avatar
a79fordman
HELP PLEASE!!!!!!!
Will a cab off of a 1990 ford truck work on a 1992 ford truck. I need help. From what I can tell. The dash from the 92 will not fit the 90 cab. Was wondering if any one has try to make a older cab fit a newer truck.
PLEASE HELP!!!!!!!!!!!!
Old Jan 15, 2013 | 06:50 AM
tjc transport's Avatar
tjc transport
i ain't rite
yes it will, but you will have to use the complete interior from the 92 in the 90 cab. the electrical system and instrument cluster are different.
Old Jan 15, 2013 | 07:36 PM
a79fordman's Avatar
a79fordman
I have the complete dash & hardware for the 92 ford truck. The problem that I have is the aluminum bracket that holds up the steering column & under the dashon the driver side seems not to fit. It don't fit up against the firewall or the kickplate. I was wondering if I just got a aluminum bracket from a 90 ford truck cab And use it under my 92 dash? What do you guys think. Thanks
Old Jan 16, 2013 | 07:17 AM
tjc transport
i ain't rite
that steering column/dash mount bracket will need to be used in the 90 cab. the 90 has a full steering column that mounts to the firewall, the 92 has a half column that mounts to the bracket.
Old Jan 20, 2013 | 02:46 PM
a79fordman's Avatar
a79fordman
Thank for the help. Not sure what I'm going to do yet. I know this coming weekend will be spent in the junkyard for a time. Think I will pickup a 90's steering column & support bracket. Not really want to put them into my truck. So I think I might pickup a left front corner of a 92 to 96's cab. Might mod my cab to make it work. The only reason I might be willing to do this is the cab that I got has like no rust. An that is hard to find around hear.
stubbfarmer
Mar 5, 2018 11:10 AM
hello113
Jul 28, 2017 04:32 PM
mrblonde108
May 8, 2008 09:50 PM
speedsauto
Nov 19, 2007 08:54 PM
StockMan
Nov 6, 2001 12:32 AM
