Sponsored by: Real Truck
Headlights
Old Jan 13, 2013 | 05:18 PM
mtbuck's Avatar
mtbuck
Headlights
I have a 2008 F250 XL and I would like to do a headlight upgrade because I am tired of the black, and I have the sealed beam. Will any assembly work or do I need a certain 1?
Old Jan 13, 2013 | 05:32 PM
Sparky04SD's Avatar
Sparky04SD
Can't help you with the "black" problem but the sealed beams can be changed out to the Hella lens and a Hella 80/100 bulb. The improvement is beyond belief.
Old Jan 13, 2013 | 05:55 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes it can be changed. Just get the normal headlamps assemblies and swap them out.
Old Jan 13, 2013 | 06:09 PM
mtbuck's Avatar
mtbuck
OK I have 1 light and it looks like the new ones have 2, is the a wiring harness I need?
Old Jan 13, 2013 | 07:40 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Same number of bulbs either way, so no harness needed.
Old Jan 13, 2013 | 07:42 PM
PSDlongbox's Avatar
PSDlongbox
I don't know how it is on the 08XL, but on my 06XL when I went from the sealed beams to the one piece headlight I had to order the proper headlight bulb connectors. I cut off the three blade connector for the sealed beam attachement, added the proper pins to the headlight bulb harness and put the new connector on that attaches to the bulb specific to the one piece headlights.
Old Jan 13, 2013 | 08:02 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Oh duh. The sealed beam is a different plug.
Rubes1982
Feb 25, 2018 04:30 AM
ErrorS
1978 - 1996 Big Bronco
Apr 16, 2012 10:04 AM
musclecars90
Oct 20, 2009 04:24 PM
fordtrucklover94
Jun 4, 2008 07:58 PM
fokkersauras
20
Jan 8, 2006 08:19 PM
