3 Questions
(1) Delay wipers only work in the last two "clicks," the fastest delay speeds. The slow delay settings do not work at all, unless I happen to be switching to or from the hi-beams or using the turn signals (sometimes, not always). Is this a wiring problem in the stick or what?
(2) Slow oil leak at the rear main... I can fix this by just dropping the trans, correct? Would seem much easier than pulling the motor
(3) It has a slight ping... transmission shifts HARD but seems to shift into higher gears very early.. when going about 25-30 its in OD or the gear before OD and pings a little under slight acceleration. I added Mid-grade gas this last time and the pinging went "ALMOST" all away.. still can hear it occassionally.. is this more leaning to being over timed or bad EGR? I have yet to check either.
Any help would be greatly appreciated! Thanks, Glen Novitsky
2) Yes
3) Are your tires the same size as the sticker in the door jamb says? If not, you need to calibrate the PSOM. If they are, then you should pull the codes and set the timing according to the sticker in the engine compartment.
Code U is the 4R70W (the truck version of the AOD-E).
quick answers, THANKS!! I think the tires and calibration are ok, because driving past one of those city (police) owned "lets see how fast the radar trailer will show" displays are right on with my speedo.... I'll break out the timing light this weekend. Thanks! Glen
