Help with cab marker lights
Old Jan 12, 2013 | 06:57 PM
superduty1967's Avatar
superduty1967
Hello everyone,
I decided to install led cab markers, I did it last year to my 02 and looks/works great, my diesel it's an 06 and my problem is the connector on the passenger's kick panel section, my 02 has a convenient plug that i used and done, my 06 has a 12 pin grey plug that none of the needles test 12volt when i turn my lights on, in the same area there are other plugs being used and connected to their respective harnesses.
I didn't test any of the other plugs because when your truck doesn't have factory marker lights, they still run the wires but leave a vacant plug that has 12v and ground for later use.
Any one has an idea?
Old Jan 12, 2013 | 07:05 PM
WillyD85's Avatar
WillyD85
I had the same problem with mine. I have an 04 i put lights on, the wiring harness is in the roof and I tried to find the plug in on the passenger side kick panel. I didn't find anything that I could directly plug into. I wound up having to wire into the headlight switch itself, I ran from all 5 lights and down the channel on the driver side of the truck and behind the dash straight to the light switch. you don't have to splice it, you can buy a connector that basically adds the wire you ran to the wire in the switch. This is what I did and have had no problems.
Old Jan 12, 2013 | 11:03 PM
superduty1967
Thanks Will,
I think i know the type of connectors you're talking about, they have like a small blade that when you press down with pliers it makes contact with the two wires put side by side, I'll pick some up tomorrow and do it like that, i was afraid to cause any power overdraw and start blowing fuses, on the other hand LED's don't pull much amps that will harm the system, don't think.
Thanks
Old Jan 12, 2013 | 11:05 PM
WillyD85's Avatar
WillyD85
Those are the ones. Let me know how the install goes.
Old Jan 12, 2013 | 11:18 PM
95PSDieselP's Avatar
95PSDieselP
same thing i done man works great. post pics when done yeah?
fordka
Sep 4, 2012 09:22 PM
peckhamjusten
May 31, 2008 02:15 PM
stroken
Sep 25, 2007 12:26 PM
dentaldave
Jul 18, 2007 12:21 AM
seabrez
Electrical Systems/Wiring
May 7, 2004 05:15 AM
