Transmisison Cooler
Old May 27, 2003 | 05:53 PM
oregon250's Avatar
oregon250
Transmisison Cooler
I just bought a good sized transmission cooler and I am having some trouble. I looked at the front of radiator today for a good mounting point (1993 F250 4X4 460/E4od and air conditioning). The air conditioning condensor is in fron of the radiator. I don't know if there is room to mount it to the front of the radiator and if I do will I restrict a lot of airflow.
If I mount it in the back of the radiator same questions. Basically I don't want to make my engine run hotter because I have a transmisison cooler.
Thanks,
Geoff
Old May 27, 2003 | 08:16 PM
steve83's Avatar
steve83
Transmisison Cooler
Air flows through the trans cooler, so you're not blocking much. It goes in front, where the air is coolest.
Old May 27, 2003 | 08:22 PM
Colossus's Avatar
Colossus
Transmisison Cooler
I hung mine off the crossmember of the grille. It came with a few brackets and it worked great. I had to overlap my coolers - I mounted 2 direct on the front of the radiator. The third is as mentioned above. Airflow goes through them so you should be fine.
Old May 28, 2003 | 07:31 PM
flyboy2610's Avatar
flyboy2610
Transmisison Cooler
The best place to put it is in front of the A/C condenser, just behind the grille. This is where I always put them.
Old May 29, 2003 | 12:52 AM
Ponyracer's Avatar
Ponyracer
Transmisison Cooler
Hey Oregon250,
When we hook up we can check out how they are stock as I have one on my truck.
cya,
Old May 29, 2003 | 12:22 PM
oregon250's Avatar
oregon250
Transmisison Cooler
Thanks for all your replies. I guess I have nothing to worry about.
Geoff
